EcoModder.com
-   -   How much more MPG would you get lowering your car 2 inches? (https://ecomodder.com/forum/showthread.php/how-much-more-mpg-would-you-get-lowering-4141.html)
blackjackel 07-29-2008 01:34 AM
I ran an estimate of 1 MPG gain, and I calculated that it would take me 70 tank fillups to justify a $100 cost of lowering my car by two inches (springs).
If it saves just 2 MPG then the figure would half!
How much improvement in FE do you guys think I'll see by lowering my car?
Here's my math:
100 gallons x 1MPG saved = 100 miles (saved per 100 gallons spent)
100 miles (saved) / 42 (my current average MPG) = 2.38 (gallons saved per 100 gallons spent)
2.38 gallons (saved) x 4.5 (approximate current cost of gas) = $10.71 saved per 100 gallons
$100 (approx cost of lowering) / $10.71 ($ saved) = 9.337 (amount of times you need to save $10.71)
9.337 (amount of times) x 100 (gallons) = 933.7 (gallons before the mod pays for itself)
933.7 gallons / 13 gallons (current tank capacity) = 71.823 (tankfuls before the mod pays for itself)
taco 07-29-2008 02:32 AM
how about this lower your car for looks then the change for mpg wont matter as much :)
Vince-HX 07-29-2008 03:19 AM
my civic has struts and springs and they allow me to corner faster which really helps my EOC on certain parts of my commute.
Btw you also should include the cost of a re-alignment If you decide to mess with your car's suspension.
blackjackel 07-29-2008 03:25 AM
re-alignment?
cfg83 07-29-2008 04:52 AM
blackjackel -
Originally Posted by blackjackel (Post 48661)
re-alignment?
Because someone will be disassembling the suspension to install the shorter springs, you will need to get the wheels realigned :
Wheel alignment - Wikipedia, the free encyclopedia
You estimated $100 for the installation. If your estimate doesn't include alignment, you may need to increase the installation estimate to anywhere from $150 to $180 total.
CarloSW2
IvanAndreevich 07-29-2008 01:10 PM
Nevertheless, he has a valid question. Does anyone have any numbers before/after lowering?
MetroMPG 07-29-2008 01:30 PM
Ivan: not that I'm aware of.
Also, the in/effectiveness of lowering will vary from car to car as well.
blackjackel: you should add your vehicle to the garage so everyone knows what kind you're referring to in all your posts (it'll appear under your username).
tjts1 07-29-2008 01:31 PM
Alignment is free.
Pelican Technical Article: Home Alignment
Big Dave 07-29-2008 01:34 PM
I lowered my truck 3" in front and 6" in back. In addition I went to smaller tires up front to get another inch.
My truck went from 76" tall to 72" tall and I gained 1.0 MPG.
The truck also corners much better.
bgd73 07-29-2008 01:37 PM
I didn't notice anything upon my own experiments. Handling, maybe looks...
geoff 07-29-2008 01:48 PM
Just having the car lower shouldnt really affect the aerodynamics, any fuel savings would come from the fact that things like spliters are closer to the ground. I would tell you not to waste your time with it if you are that concerned over only doing it to break even after 70 tanks of fuel.
If you are interested :
1) Find out what springs are avalible for your car, make sure they match what you want. Some springs may lower the car too much, or too little for what you want. You also want to check the spring rate of the new springs, to stiff will be uncomfortable for a daily driver and can shake things loose on bad roads (over time). Others may be too soft and the car can/will bottom out over big dips or with more weight in the car. The cost of a quality set of lowering springs, for a street car, will range in price from about $150-250 average. Be aware that some cheap springs will be made of cheaper materials that can break or sag over time, or they might not be well suited for the application you are using. Since springs play a major roll in the cars ability to turn, accelerate and brake...PLEASE DONT CUT CORNERS AND TRY TO SAVE $$$ IN THE NAME OF SAFETY. If a spring was to break at highway speeds, it could very easily cause a serious crash.
2) If your not going to install them yourself, add in the cost of an install. If your just having new springs put in (keeping stock shocks and stuff) figure 2hrs of labor for a shop with the right tools, if you are having it done at the same time as something else (brakes, shock change, ect) it could save you some money since some of the disassembly will already be done for the other job.
3) I would HIGHLY recomend you replace/upgrade your shocks at the time you change the springs. Stock vehicle shocks (most of the time) are valved only for the stock spring rate and ride height. Lowering the car and/or having a stiffer spring rate (almost all lowering springs are stiffer) will cause the shock to opperate outside of its normal range. This will cause the shock to have a much shorter life span or fail outright. Bad shocks will cause the car to bounce over bumps and hurt the ride quality and handling. If your shocks have more than about 50k miles on them, chances are they are already not working as well as they should. If you replace the springs and also replace the shocks with new OEM units, it will be ok for a while, but the shocks will wear out again, and faster than with the stock springs...if you find a good shock to match to the new springs you the ride quality will be better, and the life of the shock will be longer than OEM shocks with aftermarket springs.
4) You might be able to get away without messing up the allignment too bad, but chances are you will end up with a car that is out of spec when the work is done. To get the most out of the new suspension parts, youll need to have the allignment re-set. If you want to take on the challenge, you can allign the car yourself and get pretty close to the right specs for camber and toe using the "string-box" method. Caster is a little harder to set this way, but caster shouldnt change much anyway. A bad allignment will speed up tire wear, can cause a drop in MPG and make the cars handling dangerous (something like too much toe out in the rear).
Sure you could find cheap/used lowering springs and have a buddy install them for around $100, but to do it RIGHT and get the most benefit from lowering the car...I would plan on spending $200 (springs) + $450 (shocks) + $100 (allignment) + 2hrs of labor (if your having a shop do the work).
MetroMPG 07-29-2008 01:58 PM
Lowering affects aero, regardless of the presense of splitters/dams.
It can reduce frontal area slightly, improve the fineness ratio (height/length), and improve Cd. Manufacturers do lower some vehicles specifically to improve aero.
See this thread: http://ecomodder.com/forum/showthrea...drag-1783.html
Of course whether or not it will benefit a specific vehicle depends on that vehicle's starting point.
PaleMelanesian 07-29-2008 02:36 PM
It also depends on the kind of driving. If all the driving is stop-and-go city stuff, it won't make a bit of difference. If it's all interstate driving, it could make a big difference.
jamesqf 07-29-2008 03:36 PM
In my case, it would probably give me worse mpg, averaged over a year. The Insight's pretty low already, and if there's more than about 4-5" of snow on the roads, it becomes a very ineffective snowplow - which really kills fuel economy :-)
OTOH, I really wish I could figure some way to lower my Toyota pickup about 6", just to make loading it easier. Any mpg gain would be a bonus.
cfg83 07-29-2008 04:12 PM
Hello -
Which Lexus "auto lowers" at freeway speeds? How much does it lower and what are the claimed MPG gains?
CarloSW2
aerohead 07-29-2008 04:23 PM
numbers
I've never seen a specific breakdown.The really high mpg/low drag concept cars are lowered with active suspension,so they can still negotiate driveway ramps and such.They tell you what the Cd is with the "drop",however do not provide Cd for "street' configuration.If you want to slide your car under Darin's teardrop template,you could probably calculate the difference in virtual wake area,with and without the drop.Any 10% reduction in wake area would yield a 10% drag reduction,and 5-6% better mpg,at 55-70 mph,respectively, do to fineness-ratio alteration from drop.Search for" permanent Metro Kammback" to find Darin's template.
aerohead 07-29-2008 04:25 PM
Big Dave,those are useful numbers and I'm writing them down.Thanks mucho!!!!!!!!!
MetroMPG 07-29-2008 05:07 PM
Originally Posted by cfg83 (Post 48838)
Hello -
CarloSW2
I believe I read about a Cd difference of .01 for the active suspension (which lowers the car 1 inch at freeway speeds) vs. the regular car. Sorry I don't have a link handy. I think it was the '06 LS460 (Cd .26)
meemooer 07-29-2008 11:07 PM
well... if you lift a truck the FE goes down, if you lower it, most guys get better FE.
So wouldn't it be the same way with a car?
FunkSkunk 09-04-2008 06:46 PM
Found a good price on a real set of springs here --> Intrax 25-1-010 - Intrax Lowering Springs - summitracing.com
HTH
whokilledthejams 09-04-2008 07:37 PM
If it's a 4wd, you have torsion bars up front, and leaf springs in back. The torsion bars have adjusters, so you can lift/lower the truck by several inches either way. Leaf springs can be lifted/lowered with blocks. If your rear axle is below the springs, you can remount the axle above them, and get about 4" or so of drop out back.
If it's a 2wd, your best bet is lowering springs in front, with blocks in back.
I intend to lower my xB more (it's currently about an inch below stock), since A) I want the look, and B) another inch and a half in front (between Tanabe DF210 springs and Echo struts) provides all the benefits of an air dam without increasing the frontal area. Sure, I'll face more challenges in terms of terrain I can drive on, but it will be awesome, and cost 1/4 what air suspension does.
FunkSkunk 10-15-2008 01:08 PM
I'm seriously thinking about lowering my 98 Metro with H&R Coils and KYB GR2 struts. Found a couple good sources for each and think I may go for it! I'm going to be buying new tires in the next few months anyway and it might be worth it just to get all the work done at once. Once I get tires I'll have to do an alignment anyway... so why not lower the gas sipper a bit while I'm at it! What do you guys think? Oh and one of my good buddies is a mechanic so doing the alignment might be free for a few cold ones. ;)
whokilledthejams 10-15-2008 07:32 PM
Why would you get an alignment after changing tires? At best, you accomplish nothing, at worst you're wasting a lot of money.
Obviously, taking the suspension apart necessitates an alignment. That's just smart.
Of course, if your alignment is off, and you just don't want to ruin new tires, then nevermind me.
MetroMPG 10-15-2008 08:14 PM
FunkSkunk: I'm sure lowering the Metro will help, if partly because it'll reduce frontal area - the front control arms (they factor into projected area on these cars) will be tucked up more. Just a WAG, but I'd say it might be worth a 3-4% improvement in MPG.
lyd 10-15-2008 09:50 PM
What are the good sources?
FunkSkunk 10-16-2008 02:10 PM
ebay here for springs --> eBay Motors: H&R SPORT SPRINGS 96-99 GEO METRO SUZUKI SWIFT 29803-2 (item 200255299788 end time Oct-16-08 21:53:38 PDT)
(or anywhere you can get them for around $230 shipped, some online stores charge waay to much for shipping *should be around $40 bucks)
For the struts ya just gotta search on Google... I haven't found a good source yet. Seems like a bunch of people sell them, just not each one you'll need! *for example some will have the fronts but not the year, and make sure you get the ones for your model year, a lot you'll find will be for 95's and older
Tires I've been playing around with TireRack.com and think about rims and tire combo purchase... we'll see where that goes with the wife. :D link --> Upgrade Garage - Wheel Search
FunkSkunk 10-16-2008 03:11 PM
2 Attachment(s)
Just thought I'd post a picture of a lowered Metro to inspire others...
He's got springs with about 1.5" drop, and 15" rims. looks pretty good and the very small gap between tire and fender has to make a difference on mileage! looks fast but goes like a...:turtle:
