how to remove airbags - 99 honda civic
The honda civic I got recently has airbags, which freak me out as they're a time bomb waiting to happen. My major concern is if the airbags popped out with a friend in the car, and caused death or tramautic injury. Also they're extra weight and waste fuel, so I should be able to get better fuel economy without them.
How can I disable and remove the airbags, without affecting the functioning of anything else and also making sure any airbag lights don't go on? Update: Removing fuse #23 should disable the airbags. See my later posts (42 & 43) on how to get rid of the extra weight by removing them. |
The crack could have been caused by a very small chip, or no chip at all.
I'm pretty sure removing the airbags from a vehicle that came with them from the factory is illegal. I think your insurance could also get out of paying medical bills if you are in an accident that causes injury. I doubt the airbags in your '99 Civic are considered next generation, either. If you really don't want airbags, just get a car that is a few years older. |
It might be helpful to read the actual report. About two thirds of those deaths were children, and about four fifths of those deaths were in cars that are 1997 MY and older. Out of the 96 drivers/adult passengers who received a fatal injury from an airbag, only 29 of them were using a belt properly or at all. If you look at the actual figures the vast majority of adult drivers/passengers were over 55.
The general idea is that there is an increased risk for pre-1998 MY air-bags to the elderly and children, and of those deaths most of them were from people not belted in properly or at all. I don't think I would be worried about anyone except for infants in car seats in the front passenger seat. It may be safer to stick them in the back center, but only in vehicles that don't disable the passenger side airbag based on weight, and even then that may not be any safer. It's just the only situation that's possible to be safer. Everyone else was pretty much KO'd because they weren't wearing their seatbelt and/or older air-bags weren't optimized yet. |
Get a $15 shop manual and it will tell you, there should be a fuse that you can pull then at least on the steering wheel there is a little yellow clip that you install that shorts it out so that there is no way it can go off.
From what I have read, if you are wearing your seat belt air bags do very little to protect you, so in a way I agree with your desires but I tend to trust Honda engineers more then others, after all around year 2000 the Honda Civic was written about as having fewer deaths per 10,000 vehicles on the road then nearly any other vehicle on the road, the number of deaths were for both passengers and occupants of other vehicles along with pedestrians. |
So... 238 deaths in a 22 year period due to airbags. A fair number of those are infants, which you are not. In the same 22 year period, over 900,000 people died in motor vehicle crashes in the US, and the motor vehicle death rate is on the decline due to improved safety systems. You know what really freaks me out? Some of my neighbors are people who can't figure things like that out, and they vote. |
Any ideas where the clip can be found, or at least the name of it? Quote:
Any more info on how to remove the airbags is much appreciated. |
NHTSA
Good luck :confused::confused: |
I've never read the air bag part of the motor vehicle law, but I don't believe that they are required, but what is required is something that protects the driver without them playing an active roll in it, but as I understand it Air Bags are required because auto makers are required to install automatic restraint systems, first idea along this line was automatic seat belts but the lap belt part still had to be pulled across and latched so it was a net loss due to lack of use of the lap belt, ideally we would all have 5 point harnesses but that is not going to happen, so what would I like to see instead?
http://www.corkeconomics.com/wp-cont...ring-Wheel.jpg http://9timezones.com/spike2.jpg |
European airbags are designed to be used with seat belts.
