How to tell if your tires are "properly" inflated
I was heading to my car to leave and glanced down and noticed I could see _under_ the tire. The tire contacting the curb was only about 1/2" wide. 50psi
http://lh6.ggpht.com/_TdR9Pe3LH_Q/Si...2016.40.11.jpg |
Hahaha, nice. :thumbup:
Also helps keep you on track when you no-brakes-fast-corner on 2 wheels. :)
Great pic! |
I hope those are 50 psi tires :eek:
I run 50 PSI in 35 PSI tires... Still don't have problems.
There is a thread somewhere on here for the debate about tire pressures though. |
Very dangerous to inflate them that much over the recommended psi.
I do it. |
If you wish to debate tire pressure, check out this thread.
http://ecomodder.com/forum/showthrea...ires-2522.html |
