How to use the road load equation [wiki talk page]
[This is a proposed Wiki article providing an introduction to how to calculate road load. By understanding road load, you can better understand the physical phenomena governing this aspect of fuel economy. Hopefully it's written at an introductory level and helps explain certain concepts and why they matter to fuel economy. I'm wide open to suggestions as to how to improve the article. Are there any parts that are not clear enough?
Saand, if you would like to add it to the wiki, please do so, and link and format it as appropriate. I do ask that you remove the page titled Theoretical Weight Energy, as this article corrects errors on that page. Feel free to discuss that below.] The road load equation describes all the forces applied to your car: aerodynamic drag, rolling resistance, and braking. EcoModder's calculator can crunch these numbers for you for steady state driving on flat ground, if you know a few parameters such as your car's mass, CdA, and CRR. Looking through the equations behind the calculator will give you insight into what aspects of your car and driving affect your fuel economy. Aerodynamic drag is given by F = ½ * Cd * A * ρ * V². Cd*A is drag coefficient times frontal area. You can look up these values for your car in the wiki [link]. Cd describes the smoothness of the vehicle's shape, but frontal area is just as important. These variables never appear seperately from each other in the physics. Much of our work on EcoModder is an effort to improve our Cd, to move through the air while disturbing as little of it as possible. ρ is the density of air, which is around 1.3kg/m³, but varies with temperature and barometric pressure. Your car will cut through the air better when the air is thinner, e.g. when it's hotter, or at higher elevations. Don't ignore this term. V² is your vehicle's airspeed, SQUARED. This means that driving twice as fast means four times as much aerodynamic drag. A headwind or even a crosswind will give you an airspeed higher than the value on your speedometer. A crosswind will also increase the CdA of a car that's optimized for driving forward, such as a bus, tractor trailer, or a Prius. Cars and bicycles generally spend a great majority of their energy overcoming aerodynamic drag. You can improve your fuel economy by reducing any of the factors in the above equation: slower speeds, a more slippery shape, a narrower or shorter car, thinner air. Note that aerodynamic drag is not affected by mass (assuming that mass doesn't deflect your suspension). Rolling resistance = CRR * weight = CRR * mass * gravitational acceleration CRR is your coefficient of rolling resistance, a property dependent on your tire and the road surface. Low rolling resistance (LRR) tires are an excellent way to reduce your CRR. USCS people will probably use lbs for weight. The metric system makes it clear that mass is an amount of material (measurable in kg), while weight is a force due to gravity. Note that the force of rolling resistance is the same regardless of vehicle speed, while aerodynamic drag varies with V². The amount of rolling resistance per mile depends only on your vehicle's weight and CRR. So, the road load equation for steady state (constant speed) driving on flat land with no wind is: F = ½*CdA*ρ*V² + CRR*m*g. This makes for simple math, but it really only applies to highway driving, and even then not all the time. Still, studying your steady state road load gives you insight into what parameters of your car and driving cause you to spend the most gas. [The material below probably belongs in a second article] Gravitational and inertial loads Energy spent to overcome rolling and aerodynamic drag is irreversibly lost. Not so for gravitational and inertial loads. Climbing a hill takes energy, but once you start to descent, 100% of that energy is recovered. Likewise, bringing a car up to speed takes energy, and you get 100% of it back when you coast to a stop. Gravitational potential energy is calculated as: E = m*g*ΔH, where ΔH is the change in elevation. For example, consider a car with a curb weight of 1835lbs, with a 160lb driver and a 33lb toolbox sitting in the trunk. Also, the car has 8 gal less than a full tank, thus saving 48lb off the curb weight. This adds up to 1980lbs, or 900kg. When you ascend a 1000 foot ridge, you will find there is about 2.69MJ of gravitational potential energy stored in your car. This amount of energy will need to be put to use or burned off with the brakes on the way down the hill. Take the same car and accelerate from 0-60mph. Kinetic energy = ½*m*V², so you start with zero kinetic energy and end with about 0.323MJ of kinetic energy. Again, when you want to slow down, you will need to use this stored energy to coast to a stop, or burn energy off with the brakes. There is a V² term in kinetic energy, so doubling your speed quadruples the amount of kinetic energy you're carrying around. I view kinetic energy as a liability on any road with red lights or traffic, as you may need to waste that energy in order to slow down as quickly as you require to remain safe, legal, and curteous. Comparing force to energy Force times distance equals energy. Suppose you took the road load equation "F = ½*CdA*ρ*V² + CRR*V*m*g" and determined there was a force of 250N at 60mph and 367N at 75mph. The amount of energy required to travel a mile at 60mph is 250N*1mi = 0.40MJ, or 367N*1mi = 0.59MJ at 75mph. [make this equation accessible or delete it] E = integral(½*CdA*ρ*V² + CRR*m*g)*dx + braking energy + accessory loads [conclusion goes here?] |
This is very interesting and a great read for people who are interested in physics.
Good info RobertSmalls :)
I would add it to the wiki myself but I am packing for a trip :) If Saands has not done it I will do it next week when I return. You can always add it yourself, we will edit or remove if needed. |
Excellent writeup Matt :thumbup:
Make sure that you Cd is CD total, and therefore includes the form drag rather than pure frontal. :thumbup:
You show the form of the road load equation to be
F = ½*CdA*ρ*V² + CRR*V*m*g. This indicates that the resistive force due to rolling resistance is directly proportional to the velocity of the vehicle. I am surprised at this and indeed the online calculator - Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com indicates that rolling resistance is constant with respect to velocity. Which is correct? |
@cr45: Nice catch. I was thinking about power to overcome RR, which is linear with velocity.
I suggest you add a note that the RR part is only true below 50 mph and explain what happens to RR at higher speeds. |
And I noticed you excluded other tires such as truck tires. The main difference coming to mind is the thicker sidewalls and tread of a truck tire vs a passenger vehicle. |
Since I am an amature at mathematics can some one answer the following questions? Is the term g ,in the rolling resistance equation essentially one, on the on the surface of earth. With minor variations due to elevation that are small enough to be ignored for fuel economy purposes? Is wind resistance an exponental equation due to the v squared term and the rolling resistance equation linear with constant slope due to v or no other them being squared? Feel free to be wordy with your answer I welcome details. A suggested conclusion to the wiki being like the introduction that understanding the forces acting on your car you can be a more efficent driver and modifications to your car more effective.
Can you give me an alternative to CRR model? btw, here's Google Image Search for "pacejka rolling resistance": http://img519.imageshack.us/img519/9...evslongspe.jpg If the first data point had been plotted at 0.0001 mph instead of 0, it would probably match the rest of the curve. |
>Is wind resistance an exponental equation due to the v squared term and the rolling resistance equation linear with constant slope due to v or no other them being squared? I'm not clear on what you're asking here. The force of aero drag rises exponentially with speed, while rolling resistance... well, see the graph I just posted. According to the simplified model, it's independent of speed. |
It's slightly higher at the poles, lower at the equator, and gets lower as altitude increases. Local geology (mountains, rock density) can also introduce small variations. But we're talking about variations in the order of 0.5 %, tops. Quote:
(In the simplified formula.) At speed, tyre deformation (result of the tyre spinning faster) will increase rolling resistance. The more a tyre resists to deformation, i.e. the stiffer it is, the less RR will rise with increasing speed. |
http://www.barrystiretech.com/standingwave3.jpg I think that passenger car tires with their increased deflection are more suspectible to this. Truck tires - in order to stand up to the miliions of miles that they are expected to last - are designed with lower amounts of deflection. Quote:
g - in this context - is the translation from mass to weight. Those of us who are used to the English system have trouble when we talk about mass, because we usually talk about weight - pounds. But those who speak metric, normally speak in terms mass - grams. To get force - Newtons - you have to multiply grams by 0.00981. For reference, accelleration due to gravity is 32.2 ft per second squared or 9.81 meters per second squared. Quote:
I would like to thank every one for your answers to my questions. Please forgive my ignorance but I am still confused about rolling resistance. Does a car rolling down the road on say the moon where there is no air take the same amount of force to move at 10 mph as 50mph? Does force to over come rolling resistance equal power required to move an object at a given speed in this example? Is the power requierment the same at 10 mph and 50 mph? I may be over thinking this, it seems too simple like somthing for nothing. :confused:
A car in an evacuated tunnel can move at high speeds with low fuel consumption, unopposed by aerodynamic drag. According to the simplified model presented in post one, the force to move the car will be the same at 10mph or at 30mph, and the fuel economy inside your vacuum environment will be the same at either speed. Power, i.e. the rate at which energy is converted from one form to another, will be linear with respect to speed. So your motor will be working three times as hard to go three times as fast. But nobody drives in an evacuated tunnel: it would be an unaffordably expensive toll road.
The moon is a different story. A car on the moon weighs 1/7th as much as it does on Earth, so you would expect to have 1/7th the RR for a given road surface / tire temperature combination, and virtually no aerodynamic drag. Good thing, too, because energy is expensive on the moon. |
Robert, great write up. I would like to put this in the wiki, i am however very swamped at the moment. If weatherspotter doesn't get to it before me i shall put it in in a week or 2.
Looks like we might need a theoretical / modeling section in the wiki |
SUGGESTION: you can replace the "star" ( * ) symbols used to designate "multiplication" with their more (mathematically) common "dot" ( · ) symbol.
...simply, use the ALT-NUMERIC key-pad technique: 1) engage the NUM LOCK key. 2) press and hold the ALT key, and... 3) type the numbers 0 1 8 3 on the numeric keypad. ...other "useful" characters that can be entered this way are: 0176 = °, degree, temperature or angle, symbol 0248 = ø, slashed-zero 0177 = ±, plus/minus symbol 0181 = µ, latin mu, micro (10 to -6 power) symbol 0247 = ÷, division symbol 0215 = ×, multiplication symbol 0171 = «, much less than symbol 0187 = », much greater than symbol 0185 = ¹, one superscipt, unitary power 0178 = ², two superscript, squared power 0179 = ³, three superscipt, cubed power 0131 = ƒ, "f" symbol for frequency 0133 = …, ellipsis symbol 0188 = ¼, one-fourth 0189 = ½, one-half 0190 = ¾, three-quarter 0153 = ™, "Trademark" symbol 0183 = · , small 'dot' 0149 = • , large 'dot' ...comes in handy. |
I have put the initial post up in the wiki, it has been split up into 2 articles / wiki pages.
I have also made a new section "simulation and calculations", this is where we can put any tools used to simulate or calculate efficiency Simulation and calculations - EcoModder The new wiki pages are linked from this page Robert you requested that the theoretical weight energy be removed, i am happy to do this when someone offers a better alternative that will allow people to calculate the effect of weight on efficiency. I have however changed the page so that it relates to braking from 1 speed to another which "wastes" inertial energy rather than acceleration. I am open to suggestions on how to "fix" this page if anyone thinks its wrong please feel free to correct it or send me a msg. |
Looks good to me.
Thanks |
Saand,
There are numerous errors remaining in Theoretical Weight Energy, starting with the title, and continuing with the first sentence: "Weight reduction effect on fuel usage can be calculated using the following methods and equations." I wrote the "Gravitational and Kinetic Energy Equations" article as a replacement. If there is more, accurate information that you'd like me to add, let me know. Perhaps a portion on converting chemical potential energy to work? Any such attempt needs to reference the BSFC wiki. |
RobertSmalls,
i have modified the title, and the first sentence to correct what i think you have an issue with. if you want to write a direct replacement so the existing one is removed you will need to write an article that will show a method of calculating the amount of wasted fuel from the waste of kinetic energy due to braking from one speed down to another. alternatively you can look over the current one you have issues with and rewrite, that is the purpose of the wiki so anyone can correct errors or make things clearer for other readers. The reason i haven't just taken down the existing wiki page i wrote is because it was written to show users that are not very mathematically inclined what effect weight will have on their fuel efficiency. The articles you wrote are great, however dont give a path from accounting of the loss of energy to fuel use, most users (i think) are not going to care what the energy is that they are wasting rather they will care what fuel relates to that waste. in the original wiki page there are large assumptions of the efficiency of converting chemical to mechanical energy and i would be very happy for a more accurate method of calculating this conversion. I got these assumptions directly from the ecomodder online steady state efficiency calculator. I am also open to democracy, if everyone thinks im crazy and my original wiki page is inaccurate and not worth keeping up and the new clearer articles are a good replacement then im happy to take the original one down. I have gotten what i want out of the calculations, its up there for other people. |
