How to use TEGs to create power with your coolant heat
2 Attachment(s)
A little over a year ago, I showed you guys how to use TEGs to create power with your exhaust heat. To make a long story short, you can totally do it but its really expensive. I calculated over $1100 to generate 210W.
This time around, I'd like to see what we can do with using TEGs and engine coolant heat. First, lets start at the beginning again with a little recap. https://upload.wikimedia.org/wikiped...iagram.svg.png What is a TEG / peltier / Seebeck generator? Wikipedia says: Quote:
https://ecomodder.com/forum/attachme...1&d=1538503271 Alright, lets find some TEGs! We could start by finding some TEGs at the normal online shops like ebay and amazon. However, we already know price is a major concern from our last go about with TEGs. So, I'm going to go for the cheapest thing I can find that will work. For that, I checked out amazon. On amazon, I basically found a TEG that I think would work. It is 40mm x 40mm, and it is rated for higher than 100C operating temperatures. Gimiton SP1848-27145 TEC 40x40mm Quote:
By looking at this, we can get an idea of how much the one TEG module will generate. We know coolant temps are around 190F when the engine is warmed up. I'm going to use 70F as an ambient temperature. Obviously it will get better or worse depending on the environment. Now, lets convert to units the rest of the world uses. 190F = 88C 70F = 21C So, we have a temperature difference of 67C. Lets round down to be conservative. That means our TEG will put out 2.4V and 469 milliamps, right? Wrong. Open circuit readings put no load on the TEG. As you put a load on it, the voltage will drop. The same thing happens with solar panels, and batteries. The amperage reading I believe we should be able to take as fact because there must be a load for there to be amperage. So, by my previous experience with TEGs, we can take the open circuit voltage and divide by 2 to get an idea of what we'll actually see while its in use. Thus, we will get 1.2V and 469 mA, or .56W per TEG module. https://ecomodder.com/forum/attachme...1&d=1538503479 How many TEGs do you need? This all depends on how much power you want to generate. A typical small alternator puts out a max of 80A, or around 1100W. So, if you wanted to generate that kind of power you would need 1100 / .56 = 1964 TEGs. Kind of ridiculous, right? How about we look to achieve something more reasonable like reduce the alternator's load by 10A or 135W. That means we will need 135 / .56 = 241 TEGs. Still seems pretty silly. That is over 4 square feet of TEGs to mount and install somewhere! And, this is really where the TEGs creating power with coolant falls apart. You're talking a ridiculous number of TEGs to create any sort of real power. 10A won't even power a normal car going down the road. Cost Let us look at the cost aspect real quickly. The SP1848 TEGs currently cost just under $2 each shipped from China. If we get 240 we pay $480 for ~134W of generating power. We still need to mount them to something, run coolant to that something, and put a heatsink on the other side. So there is plenty of cost there as well. Just the TEGs themselves cost $3.58 per watt. That is actually an improvement over the exhaust powered TEGs which came in at $5.23 per watt. For kickers, lets also compare this to solar power. Solar panels can be had for under $2 per watt these days. The wonderful thing about solar is you can generate power no matter if you are driving or not. As long as your solar panel is in the sun, you're generating power. This is a huge advantage (unless its overcast of course) as your solar panel can chug along all day long vs just the 30 minutes you're driving to work. Of course this assumes you're running a deep cycle battery, but I digress. Solar is still cheaper, and still almost nobody uses it. Conclusion So, can it be done? Certainly. Is it practical? Sadly, no. Not even close. It seems TEG efficiency will need to increase and/or price must decrease a good amount before this would be viable as a DIY project. |
Substitute the word battery for TEG in your conclusion, and it sounds just the the current series of arguments in EV vehicles.
Could you do this instead on the exhaust? You would get a much better hot/cold side differential.
https://www.sciencedirect.com/scienc...14157X14000033 Fig 5 is a Honda prototype: https://www.sciencedirect.com/scienc...5943111501128X |
^^It's literally in the first line of his first post:
https://ecomodder.com/forum/showthre...eat-35394.html |
So if you mounted TEGs on both an aluminum radiator (side tanks) and the exhaust, you could just about do away with the alternator, but you’d pay over $2k for it...
Yeah! I think it is pretty awesome that we COULD do it if we either didn't care about money, or landed a nice score of super cheap or donated TEGs...
Use solar panel and teg to do an alt delete.
Use teg so the battery doesn't drain as fast while driving. Then solar panels can replenish the battery during the day. The teg would also continue to make some power after the car is turned off. But if you have an electric vehicle you don't have to worry about any of that. |
I would not want to wire that thing.
The cooling would also be a nightmare. You would probably need to redesign the radiator. Maybe make it flat and put it under the car. |
1 Attachment(s)
I've been considering both TEG sides .. My ideal (might not end up being doable) would be to combine both (radiator and exhaust) TEG with a Meredith Thrust style air flow over the 'cold' air .. as the 'cold' side air absorbs heat via the TEG transfer , that cold air will heat , and expand .. and if designed right produce minuscule additional amount of thrust at the same time from the same heating of that 'cold' air :D https://ecomodder.com/forum/attachme...5&d=1538603669 |
I think the easiest way to do it would be to pipe some coolant up to the front of the car that way you can heat the hot side and cool the cool aide with outside air.
