Old 09-18-2010, 01:19 AM   #1 (permalink)
Hi - New with BMW 318i modder
Hi,
I just joined and wanted to say hello. I have a 1984 BMW 318i that used to get 30 mpg on its own. I'm up to 35 by simply dropping weight. I use the car only for myself since I have a 120 mile commute each day. I took out the entire interior except for my seat. I am enjoying my new found modding hobby and look forward to learning from all of you.
Old 09-18-2010, 06:25 AM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Welcome to the site!
Old 09-18-2010, 08:15 AM   #3 (permalink)
Hypermiling rookie
Laurentiu's Avatar
Opel Corsa B - '96 Opel Corsa 1.2 8V
90 day: 47.27 mpg (US)
VW Bora 1.6 16V - '02 Volkswagen Bora/Jetta
90 day: 35.84 mpg (US)
is it manual or auto ?
and...WELCOME
"It has been my observation that most people get ahead during the time that others waste" Henry Ford
Old 09-20-2010, 11:02 PM   #4 (permalink)
The car is manual.
Old 09-21-2010, 07:42 AM   #5 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
is it an e30?
if so, do you have the m10 engine?
I see you ahve injection, so you're onto a good start already.
It may be worth converting to a later management system so you can benefit from the better fuelling maps..
post up a pic of your car- I've got 2 e30s at the moment, and possibly a third on the way
Old 09-23-2010, 03:09 AM   #6 (permalink)
I suppose it's an e30? This is my first BMW so I am barely have enough knowledge to keep it running so far lol. How would I know if it's an M10 engine? I don't have a clue how to map an ecu, let alone one from OBD I era.
Old 09-23-2010, 07:27 AM   #7 (permalink)
Team m8
It should look like this if its an e30...
the m10 engine is the 4cyl engine that was fitted up until 1988- if you put up a pic of your bay, i'll be able to tell you exactly what you have!
ecu upgrading is fairly simple, as is an engine swap! they're easy cars to work on!
Interview with BMW aerodynamicist Hans Kerschbaum Piwoslaw Aerodynamics 13 06-11-2010 04:59 PM
BMW advocating for smarter traffic lights abroad and in U.S. MetroMPG General Efficiency Discussion 14 11-13-2009 11:34 PM
Hey all -- Old BMW driver here! SmittyNC Introductions 3 11-25-2008 12:42 PM
Article: BMW Plans All-Turbo Line RH77 General Efficiency Discussion 2 10-10-2008 12:10 AM
