Hub motors
Innovative Wheel Motor Could Change EVs - Autoline Exclusives
35KG means 150lb of unsprung weight with two-wheel drive. In other news, Buckminster Fuller's Dymaxion Transports used a hinged frame that put the sprung weight and engine on opposite ends of a lever with the passengers in the 'rocking chair'. These two-speed hub motors in an H-frame suspension with the battery box[es] could give a nice ride in a heavy car. |
This in turn puts me in mind of the Autospeed article on tuned mass dampers:
www.autospeed.com/cms Mounting big driving lights, Part 2 If the battery box weighs more or less than the tire/wheel/hub motor combo the lengths of the lever arms compensates. Spring rate from the resonant frequency. |
Maybe no-one else thinks about this but I do.
Today I wonder about inwheel suspension and an unsprung hub motor. The innovation here is putting a twospeed transmission inside the motor rotor. Else the motor would have to be twice as heavy. On the downside it does require an hydraulic system for cooling, lube and shifting. |
The various ways to do suspension and where to put motors have already been played out, and the better ideas selected.
I think about how to provide a 1G environment for sojourners on a long mission to other planets. Seems to me inflatable habs are the way to go, especially when they're going to be pressurized anyhow. |
https://www.carbodydesign.com/media/...03-720x482.jpg https://www.carbodydesign.com/media/...03-720x482.jpg Quote:
What do you think of Think Orbital? ThinkOrbital - We build space Space infrastructure company HQ to be setup in Colorado Domes in spaaaace! |
The suspension's in the 'spokes' here:
https://www.youtube.com/watch?v=qxKJu_-0rUA Except it's not; it's just a digital design at this point. How would one control the variation in the speeds of each motor to make this work..? Then how much energy would go into keeping the car suspended..? Regen?? Another problem is that one long motor is way more efficient than 3 short ones. (copper fill and all that) But ye; if one can get suspension into the 'spokes' it'd be a great step forward for electric motoring. |
A Xongda? IIRC. Edit: Found it https://endless-sphere.com/sphere/th...d-motor.59369/ |
I'm looking for info on the suspension now. |
They apply power to the spokes, but only for vertical suspension. It would also work at 90 degrees. If the axle moved forward, the vehicle would think it's rolling downhill. Or not.
Edit: en.wikipedia.org/wiki/The_Very_Light_Car Quote:
I thought Edison2 should've put their inwheel suspension on a 1937 Ford (one-year-only) tube axle and taken them to SEMA for street rodders. |
https://www.youtube.com/shorts/UkNI_OYMXrI |
A thing that's been bugging me:
There's all this dangerous radiation right; fast moving Alpha, Beta and Gamma particles. 2 of the 3 particle types are electrically charged. (Alpha and Gamma IIRC) Yet NOWHERE do you see an attempt to set up a protective magnetic field around space habitats..? You'd think such a relatively light and obvious way to block most of the radiation would have been considered despite the magnetic field being something of a problem when you 'just have to' work with ferrous metal tools etc. A ferrous metal cylinder habitat should concentrate the field density in the skin, where it would be equally to more effective, leaving the interior relatively free of magnetism..? |
I have seen suggestion to make a magnetosphere for Mars by placing some device at the L1 Langrange Point, upstream in the Heliosphere.
[taurus ≠ torus] |
