EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   HUMMVEE front wheel skirts (armored)... (https://ecomodder.com/forum/showthread.php/hummvee-front-wheel-skirts-armored-31205.html)
BamZipPow 02-12-2015 11:28 PM
http://i677.photobucket.com/albums/v...psae3cfc62.jpg
Notice the rear wheel skirts, too? ;)
2000mc 02-13-2015 02:52 AM
guess it's still an ecomod, theirs help maintain rolling resistance
RedDevil 02-13-2015 04:01 AM
That ain't coroplast.
They make electoral signs out of 1/4" steel over there :confused:
Fat Charlie 02-13-2015 08:19 AM
If your wind tunnel used shrapnel instead of smoke, that would be a good design.
gone-ot 02-13-2015 12:04 PM
Originally Posted by reddevil (Post 467843)
that ain't coroplast.
lol :)
cowmeat 02-13-2015 05:44 PM
Pretty sure those are the same wheel skirts I put on Black Widow
freebeard 02-13-2015 09:41 PM
Needs more airdam.
And a scary clown face.
gumby79 07-12-2015 04:57 AM
Notice the handles to pull them off to check the oil. :cool:
forward opening hood finder to finder.:confused:
gumby79 07-12-2015 04:59 AM
Doesn't look like they're worried too much about that with all the sandbags and whatnot on the hood.
Fat Charlie 07-13-2015 11:26 AM
The sandbags are blocking the upper grille. I'd skip any grille block over there, personally.
Xist 07-13-2015 03:00 PM
Actually, I saw many grill blocks in Afghanistan--cloth. I guess that when you have more dust than oxygen in the air, you need a filter.
The donkey CRX 07-13-2015 03:54 PM
Needs more Cowbell!!
Fat Charlie 07-13-2015 04:35 PM
No, they'll hear you coming!
gumby79 07-13-2015 11:59 PM
1/4" plate on standoffs would be lighter more airo than 4 30- 50lbs sand bags also would breeath better
as for filter any one who has commuted throw bug country knows how plugged up a radiator can get with small particulate bug bodies (over there sand)
gumby79 07-14-2015 12:02 AM
Then agen they are sandbags sooo not going to stop the sand packen jmo
Frank Lee 07-14-2015 12:13 AM
Skirts and spats all in one swell foop!
elhigh 07-14-2015 09:44 AM
I wonder if kevlar skirts would get the job done in similar fashion without adding so much weight. I remember hearing about lots of breakdowns from field armoring overloading the suspensions.
Xist 07-14-2015 10:15 AM
Much of the armor on trucks is aluminum, too, so there are plenty of better options than steel.
freebeard 07-14-2015 12:04 PM
'field expedient'
Fat Charlie 07-14-2015 03:39 PM
Hilbilly armor made the suspensions cry, but it was the powertrains that really suffered.
That much added weight (in the OP) to protect... tires? Really- adding armor made people think of those puny little trucks as tanks. The old Toyota pickup with a machine gun mounted on a post in the back is a much better weapons platform in that environment because you can't armor a vehicle enough to matter and still call it a vehicle.
Xist 07-15-2015 01:15 PM
Charlie, we drove Hili (Plural of Hilux? :) ) on-post (left-hand-drive!), but all of the Afghan National Army that I saw drove Rangers.
As for putting armor over tires, I guess they could not afford bullet-resistant tires.
When I first deployed, they told us to not raise the cabin on our MTVs, the hydraulics could not support the added weight of the armor.
No problem.
We have Sergeants insisting that we do not properly PMCS (inspect) our trucks here unless we raise the cabin.
That is not part of the standard PMCS. Also, even though I try to understand cars, you show me an engine, and I will say "Yup! That is an engine!" I cannot necessarily recognize a problem.
