EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Hydroelectric overview (https://ecomodder.com/forum/showthread.php/hydroelectric-overview-41748.html)
freebeard 04-04-2025 04:40 PM
The Future of Hydroelectric Power: From Mountain Streams to Ocean Tides
A more down-to-Earth episode for Isaac Arthur -- he doesn't get to Outer Space until the last few minutes. :)
The most interesting new concept IMHO is Dynamic Tidal Power. More adaptable to extended, shallow coastlines than barrages. It seems like barrier islands would make good candidates. Two half-circular fish farms to create a venturi with turbines at it's throat.
Toward the end he hints at deep-sea power sources, but says it's speculative and doesn't mention OTEC
Ocean thermal energy conversion
Ocean thermal energy conversion is a renewable energy technology that harnesses the temperature difference between the warm surface waters of the ocean and the cold depths to run a heat engine to produce electricity. It is a unique form of clean energy generation that has the potential to provide a consistent and sustainable source of power. Although it has challenges to overcome, OTEC has the potential to provide a consistent and sustainable source of clean energy, particularly in tropical regions with access to deep ocean water. Wikipedia
