EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   "Hypermiling" counterproductive? (https://ecomodder.com/forum/showthread.php/hypermiling-counterproductive-2444.html)
Dust 05-20-2008 03:48 AM
If you take a look at my mileage, you will see that I have a few tanks in the log. The worst one was being nice to the car. No boost, slow starts, watching lights, etc. Yielded 10.4something KMPL. The next tank, before I got tires for the car, was a lot of boost, climbing a mountain, and not really being nice to it. Yielded me 15.4 KMPL. The tires were a little mismatched when I bought the car; 165/55/14 and a 155/65/14, and I filled up early on the last tank to kind of reset after buying new tires and an alignment. I used some Fuel Power Plus for the first time on the third tank, and a stronger dose on the 15.4 tank. That’s a lot of difference. Is it because I didn’t have much throttle on the 10.4 tank, and more throttle makes better mileage? What am I missing?
mattW 05-20-2008 04:43 AM
Engines actually run more efficiently (per kw/hp) at wider throttle angles so you can actually accelerate too slowly for FE and its better to cruise/hill climb in a high gear with open throttle then at high rpm/low throttle. You should probably look at your engines BSFC map to see where to keep the engine.
Dust 06-01-2008 09:01 PM
With a turbo in the mix, does pulse and glide include getting into boost too?
Daox 06-01-2008 09:08 PM
Do you have a scangauge? If so, set it to monitor closed/open loop mode. You should be accelerating as hard as you can without bumping it into open loop mode. In open loop you will be running rich air/fuel ratios and loosing the benefit of P&G.
Dust 06-01-2008 09:21 PM
No OBD2. Really wish it did though. Life would be easier. May pick up a wideband though, although the cost benefit would be rather dim.
Daox 06-01-2008 09:36 PM
Check out this dodad. It should allow you to monitor open/closed loop. I made and used one for a while on my 96 Tercel.
http://autospeed.com/cms/A_1716/article.html
Copyright ©2000 - 2021, vBulletin Solutions Inc.
