Hypermiling an Iconic Gas Guzzler: Help!
It's easy to get good mileage out of a prius, but what about big utility vehicles? Can an Explorer be economical, or is one better off buying a Corolla? My target for this project is 22 mpg.
The Truck 2000 Ford Explorer Sport 4x4 (2 Dr) 4.0L OHV V6 4spd w/ OD manual transmission 4.10 gears 15.85 gallon tank Stock rims/tires EPA RATED: 15mpg city 19mpg highway http://i85.photobucket.com/albums/k4...2/100_1853.jpg Tank Number One - 100% city driving - 15.2 mpg This was my control tank. Normal driving, no mods. It confirms that my truck can meet the EPA estimate and there are no major defects affecting mileage. Tank Number Two - 100% city driving - 17.2 mpg Driving behavior: Relaxed speed, coasting to lights, using highest possible gear, no idling. Physical modifications: Changed oil and filter, changed air filter, cleaned mass airflow sensor, cleaned injectors, removed roof rack, removed excess cargo weight, inflated tires from 30lbs to 35lbs. What can I do from here guys? 2 mpg is a reasonable increase, but I'm not sure what else I can do for a truck like this. I really appreciate all comments and suggestions! Thanks! |
You could try a grill block, belly pan, smooth wheel covers, etc. What kind of driving constraints do you have in the city?
Welcome to ecomodder! |
Theres a dude on one of the explorer forums that pulls 30MPGs from his rig. So its totally possible.
Welcome to EM |
Hey Red,
I've seen that thread on the explorer forum. That guy however, has an advantage in that his truck is 2wd, better gearing, SOHC engine, lowered, custom chipped, etc. I am just hoping I can hit 22 mpg without spending a whole pile of cash! By the way, that guy is incredible and here is his truck: http://www.explorerforum.com/forums/...d.php?t=137531 |
Well at least your Manual ...
I would consider raising your tires up to sidewall max psi. I am currently running my V8 4-runner @ 50psi and the vehicle glides better than my Vibe. I'm sure its because of the added weight. Anyhow, once you have better rolling you'll see you can coast longer distance in neutral. Also, consider shutting the car off so you have no idle time while sitting still. I cry as I watch the mpg meter plunge every time my wife sits at a light with this beast. That also means cutting out drive thrus, bank tellers etc, get into the habit of walking in. The grille block should help, especially if you hit hwy ever. I am currently sitting at 23mpg with the 4-runner with this tank, so your numbers are not to far from possible. And last but not least if your tank is larger than 15 gallon consider running with 1/2 a tank or less if possible for weight reduction there too ...that however messes with your mileage tracking, so pick your poison. |
I like the grill block idea. I went ahead and did that on mine first. Warms up faster and seems to push more air over the car. Another quick and easy thing you can do is take off the roof rack. If you want to be lazy like me taking off the cross bars makes a decent difference. Your side channels look like there pretty low anyway.
Anything can be hypermiled. Since it mostly city Aero won't help that much. I agree with the grill block. Any chance of a getting a scan gauge? That alone could probably hit the target. Route selection is key. Might want to back into the drive way for the quick get a way when the engine is cold. Take a look at the 100+ driving tips. That's where you will get your biggest bank for the buck.
As far as car comparison you'll need to run the numbers to see if getting the Corolla will pay off. Good Luck and welcome to the site.:turtle: |
LRR tires will get you better mileage, when you're ready for tires.
If I were you I'd go with the basic cheap mods and technique. Mods and technique will only get you so far though.
You didn't tell us how much you drive and why you need a SUV. Over the lifetime of a vehicle, the single biggest expense related to a vehicle is often gas. If you drive a lot, and don't haul stuff around all the time, I would consider buying a metro or the like and keeping the truck only for when you really need it. |
Besides just changing the oil, you should switch to synthetic. Changing the tranny, transfer case, and both differentials to synthetic fluids will also help with efficiency.
Do you ever actually use the running boards to get in/out? Would not having them cause issues in access? If not, remove them. |
Some more ideas:
Remove trailer hitch Remove passenger side mirror. Remove rear seat (you can't get back there in the 2 door explorer anyway!). Convert to 2WD (remove the transfer case, axles, etc.) Investigate if there is a lower final drive available (4.10 is really high!) Consider going to 0W20 synthetic. The new Ford's use it. Cold air intake? Dual exhaust? Headers? I have no idea if these are available for your ride. |
Got another rather radical idea...
I bet that you could remove the rear bumber, no problem. Investigate if there are any skid plates that could be removed as well. |
Pull the crossbars on that roofrack.
You are doing well for city driving. I know some cars will give about double the mileage for highway driving compared to city driving. Of course, there is a wide range of conditions in city driving.
I would suggest first that you try letting your engine breath hot air from around the engine. This might mean disconnecting an air intake hose and stuffing a rag into it so it doesn't bring cool air into the engine compartment. If your ignition timing is adjustable you could try advancing it a little. Don't overdo it or you could get knocking. I've had good results when retarding the camshaft a few degrees. The torque goes down but MPG goes up. The distributor has to be readjusted to avoid retarding the ignition timing too. If your engine already has variable valve timing this tip might not help. To get a really big improvement you could try something like the old Crower Mileage System (CMS). The plan is to raise the compression ratio to about 14:1 (by installing different pistons) and install a camshaft that closes the intake valves about 40 degrees later than normal. The result is a reduction in pumping losses and an increase in expansion ratio. Crower doesn't sell this camshaft anymore but I noticed that some companies such as Isky Racing Cams have camshafts for turbocharged engines which have a longer duration for the intake valve. Isky calls theirs "Turbocycle". You can also order a custom made camshaft. There could be a problem of complying with emission regulations if you do engine modifications. Of course this kind of thing gets expensive. Your wheels look big and heavy. Maybe you can get some wheels from the junkyard which aren't so wide. If you keep the same diameter tires then the speedometer will still be accurate. Alternatively, you could look for narrower tires that fit on your original rims. A less aggressive tread should reduce rolling resistance and wind resistance. I doubt you would gain much from very high tire pressures and it would give you a rough ride and extra stress on the suspension. I would also be concerned that a tire might explode while you are filling it if it is getting weak. I think the main problems are that your engine is large and you have a heavy vehicle. The large engine will consume extra fuel at light loads and the high weight will require extra horsepower when accellerating and climbing hills. I suggest that you keep a bicycle in the truck and use it for short trips when you don't need to carry much. Keep it hidden under a blanket so it doesn't get stolen. |
how far is your city driving, can you use a bike?
All very good suggestions guys, I appreciate your help a lot.
Roof rack and step bars have been removed. Grill block I have considered, but it does get pretty warm here and the explorer usually comes to operating temperature very quickly. Maybe if I get a scan gauge to monitor the rad temp, I'll go ahead with this one. Scan gauge, by the way, it's interesting that you said that one of those could get me to my target Lazarus. Does the scangauge actually alter the ECU for mpg? Or are you just talking about monitoring my driving habits? Removing the rear seat is unfortunately not an option because I sometimes have three passengers. Removing the transfer case and converting to 2wd is also not an option because of six foot snow drifts in the winter (stupid canada). Can't remove hitches, bumpers, etc. because this is essentially a work vehicle and needs to be prepared to tow. Sidewall pressure for my tires is 40lbs so I will add another 5lbs to them. Skinny/LRR tires would require new rims ($$$) and decrease the GVWR payload. The computer on this truck is quite *****y and there is already a valve tick so I don't want to play around with timing. Overhauling cam/pistons is definitely out of budget. The air box however does pull in warm air. The reason why I need the truck is because I deliver building materials to contractors. This is why towing and payload capacity need to remain unchanged. I don't have a bike but for personal trips we use the wife's 1.5L hyundai accent which gets 35 mpg in the city. |
Switch to an electric fan setup. Google taraus fan and see what people are doing. It did help my Suburban..
Well, at least you're using your SUV for its intended purpose: towing, hauling, driving in the snow, etc.
I had a 2001 4 door Chevy Blazer. It was 2wd. It actually got pretty excellent highway mileage. 22 or 23, once I got that roof rack off, got rid of the hitch, folded back the passeger side mirror, etc. But I wasn't really using it for its intended purpose, so I traded it in and got the Saab. |
I've got a 2000 XLT with the 4.0 OHV. Mine is 2wd, which helps, but with an auto trans, which does not. My lifetime mileage on the truck is ~19 mpg. My last tank netted me 22.3 mpg. Thats on a 65/35 mix of hwy/cty and a lot of A/C use. To date I have removed the roof rack, both exterior mirrors (have a small blind spot mirror inside drivers side), FM antenna (have Sirius radio), windshield wipers (using Rain-X, but I leave them in the car in case of emergency), and a partial grill block. Doing some shifting into neutral and slow acceleration, but I can't do much without a manual trans.
Looking for some underbody airflow work next. |
Atleast you use your truck. Guys I work with here just drive them and don't even need them. They claim they do but they work at the Fire Department where you just have to get to work... We have a Big Red Firetruck. It is a city fire dept. I currently live 8 miles from work. I have debated jogging to work. My jogging cap right now is around 3.5 miles. And you said you use the accent around town. Sounds like you can just do the mods you have said and just work on the driving. Good luck let us know how it turns out.
I'm planning a 450km (280mi) trip later this week, I'll let you know how she does on the highway with the tires at 40lbs and the roof rack off.
A couple questions about highway driving...do you guys find that it's better to use cruise control or your own foot? Since this is a rather large vehicle, would it be more economical to speed up before the hill and coast down it? |
Regarding using the cruise: I use cruise as long as the road is perfectly flat. I shut it off on slight up-and downgrades, keep same pressure on pedal, let the car slow down over the crest and pick up a little speed going down the other side, just like the truckers do. Works on my Dodge Stratus, 34 to 36 mpg, no mods.
Ray Mac |
Considering that you are talking 100% city driving the only thing you could do for a radical MPG improvement is seriouslt radical surgery: Remove the engine and put in a 4BT3.9 Cummins diesel. The diesel is far more efficient in low-power operations as you don't modulate power output by making the engine less efficient (throttling) but by merely reducing fuel flow.
This is a mechanically ambitious project and definitely not for the faint of heart. No, I don't know if the Cummins will fit. Fords have notoriously small engine compartments. I do believe some motorheads have down 4BT3.9s into F-150s though. Cheap-charley efforts will yield cheap-charley results. |
thats what i do with my cruise as well. fellow explorer owner chiming in here. you have the SOHC motor, btw, just like my '01. but you have the stick shift, which is going to be an advantage (i have the auto). since you have the lower (4.10) gears, you can probably step up in tire size a little to get your rpms down on the highway. but your speedometer will be off, and your odometer. its easy to calculate actual mileage, though. my explorer sport (2wd) is lifted on 31" mud tires (which will fit stock too), and i've broken 20 mpg more than once. so far all i've really done is bump up the tire pressure to 40 psi (tires are rated up to 45), removed the roof rack (rails and all are easy to remove), all synthetic oils, and adjusted driving habits. i think your goal is easily attainable. i would follow some of aldive's mods such as some of the pulleys and the electric fan. lots of good ideas in this thread. partial grill block would be a good start. the wheels are aluminum and only 7 inches wide, so i'd keep them. not sure about your sport's body style, but mine (01+) has a nasty grill-to-hood gap. i can see the hood flexing from the wind while going down the highway. i plan on finding some type of seal to close that gap. oh yeah, explorers sit butt-low from the factory. you can drop the front end about an inch to level the truck out (which should help aerodynamics as well). check out the lowered/sport section at explorer forum (where aldive's stuff is) for more info on that. btw, reading all the driving tips on this site got me my first tank of over 20 mpg with no mods to my sport |
I have a '96 Ranger XLT Supercab (4x4, 4.0L, auto) with 32" mudders, and I always get around 16 mpg. That's babying or racing, cold or hot, loaded or empty. We get heavy snows here sometimes, and I occasionally have to haul junk to the dump, so we still need it. So, we parked it and bought a used car for me to commute in. It now sees only a couple thousand miles a year.
Similarly, my dad (an electrical contractor) parked his 2500HD (V8, auto, 8 foot utility body) and bought a 5 speed 4 cylinder regular cab Sonoma. He still hauls his basic set of tools, and can even tow light trailers, but he gets 22 mpg (driving fast), compared to 12 in the 2500. When he needs the full set of tools or towing capacity, he can still drive the 2500, but the rest of the time, he's buying half the fuel. |
I didnt know they still offered 5 speeds in explorers in 2000.
How pumped up are the tires?
How slow can you drive? Those 4.10s are gonna kill any economy at speed. Do you shift to neutral and glide every single chance and almost never touch the brakes? |
after reading over this thread some more, i noticed that this rig is pretty much city driving only. i think the lower gears may be of benefit. by timing the stoplights, he may never have to drop down into 1st gear. that ought to help a little. plus he can drive in OD at a lower speed, and go through gears faster to get there.
Also, tires make a huge difference. My truck lost 15% mileage when I switched from highway tires to M&S. Consider two sets of tires - highway tread for summer and use winter tires only in the winter. |
I vote for a couple "performance" type upgrades, to give a little more torque. Air Intake, Exhaust, Headers, as previously mentioned. Let the thing Breathe. I believe a throttle body spacer is available for this too. This should give a little more torque, so less throttle is needed to get moving. Keep the 4.10 to help umph off the line.
Be cautious of the fuel level getting to E. The moden cars use the fuel for cooling, so 1/4 and less poses the higher risk of fuel pump over heating and wear. All your MPG go right out the window when replacing electric, high pressure in tank pumps, which equal hundreds of dollars, plus labor, if applicable. |
Explorer rear axles are a dime a dozen (8.8 ford rears with disc brakes even) at junkyards. Plenty of them come with 3.73 or taller.
Swap the rear and see if it does any better. Then decide if you need 4wd bad enough to swap the front. Ditch the roof rack and running boards. If all else fails, get a truck like mine. You can get great mileage with your payload in the back, rather than needing to get a trailer all the time. Then when you really need a trailer, get it. For you, anytime you need to haul, you have to get the trailer. Sure I'm slow, but it only matters a few minutes on a long trip. And yes, my truck has 4.10s. |
