Old 01-04-2012, 11:44 AM   #1 (permalink)
Sitikka - '03 Citroen C5 2.2 HDi
New guy from Finland.
Hello to you all from the land of expensive fuel. As the distance to the Russian border (and cheap fuel) I decided to do something for the fuel economy instead.
Car: 2003 Citroen C5 Break, 2.2HDi + 4spd auto
Current mods: tuned ECU, low rolling resistance tires, FAP deleted, EGR blocked, some car weight deleted and adjusted driving style. Doing now 5.3l/100km on mostly highway cruising (~44 mpg).
Interested in aerodynamical mods. Too bad replacing the auto with stick tranny is a job far beyond profitability. These computer cars need half of the stuff replaced inside when you change the transmission...
Old 01-06-2012, 10:56 AM   #2 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Welcome, tervetuloa,
You can find lots of information related to aerodynamic modifications here. on Finnish winter its important to block the radiator grill. you can block it fully without any problems.
Also the oils should be as thin as possible and use the block heater if you have one.
One easy mod is to change your tires to narrower and taller.
If you are willing to change the looks of your car then there are more options.
If you need help on your car I can help also in finnish.
Vesa Tiainen
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 01-10-2012, 11:46 AM   #3 (permalink)
Mieluummin suomeksi kirjoittelenkin. Laitan yv:tä.
Old 01-10-2012, 09:16 PM   #4 (permalink)
Welcome kimmoa!
