08-08-2009, 09:45 PM
My Goal: 35 MPG All Day
Were my tires throwing off my fuel logs? Help
Hey I was looking at a profile on here where someone said that the tires on their car or whatever it was were 6% bigger then the stock so he calculated the 6% into the fuel logs for 6% addition to the miles driven. The tires I had on for a while are 10% bigger then the stock/ones I have on now. Was I suppose to add in that 10%
08-08-2009, 09:57 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Yes. :P You screwed up.
What you actually have to do is calculate the difference in rolling circumference, not diameter. You add in the % difference of the circumference, since you've gone that much further.
08-08-2009, 10:01 PM
So can you tell me what I need to do to my fuel logs for when I had those tires on? add or subtract from them and by how much?
08-08-2009, 10:02 PM
If your tires were 10% bigger circ, you add 10% to the miles driven.
08-08-2009, 10:16 PM
So that chart is correct? I DO use 10% in this situation?
If so then for ex. if I drove 300 miles I should take 10% from 300 and add it to the 300, that being 330 and put 330 in the place of the 300 right?
08-08-2009, 10:21 PM
08-08-2009, 10:23 PM
are you 100% sure before I go and modify 9 of my fuel logs 4ever?
08-08-2009, 10:26 PM
Do I have to support my statements with logic?
08-08-2009, 10:28 PM
#9 (permalink)
No, besides I cant argue with writing down a less-good FE than it was
08-08-2009, 10:30 PM
#10 (permalink)
It'll show better mileage... more distance on the same fuel.
