EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Hyundai releases official photos of the Ioniq (new: video) (https://ecomodder.com/forum/showthread.php/hyundai-releases-official-photos-ioniq-new-video-33311.html)
RedDevil 01-07-2016 05:00 AM
Hyundai Releases First Official IONIQ Images
Hyundai drops first official pics of Prius-rivaling IONIQ
http://4.bp.blogspot.com/-W4Ueg2rm_d...rst-pics-9.jpg
We’re calling it a “three-in-one” because Hyundai will sell the IONIQ as a hybrid, plug-in hybrid, and pure EV. The first to see the light of day is the hybrid version depicted here with a design that probably won’t create as much controversy as the latest Prius. That being said, the way this car has been styled clearly shows it will compete with the Prius on all fronts.
Just like the second gen Insight did - this is more like what a 3rd gen Insight should have been.
Paint it red then I may wonder why it does not react to my remote.
Nonetheless, this is a practically sized car.
The plugin version will give the Volt a hard time.
The full electric version would fill a niche, there's no other full electric car in that size and shape yet.
cRiPpLe_rOoStEr 01-07-2016 08:02 AM
At least in that picture it doesn't look bad.
Zach 01-07-2016 08:33 AM
I was reading about that last night, first to be released in Korea
"[Ioniq] would be rolled out in mid-January in Korea with a starting price of about 22.9 million won ($19,145), similar to the basic version of its Sonata mid-sized sedan."
And also talks about aerodynamics.
"Good aerodynamics were a major driving factor behind the design and Hyundai has already claimed the car will have a “class-leading” drag coefficient."
MetroMPG 01-07-2016 09:56 AM
Some spy pics were also captured of the new Hyundai, completely undisguised. I won't post them, but here's a link:
I like the styling and the design.
I also think it's geeky cool that they showed the rear of the car in the first official photo, since that's the most important end from an aero efficiency standpoint.
oldtamiyaphile 01-07-2016 10:46 AM
1 Attachment(s)
Some specs:
http://ecomodder.com/forum/attachmen...8&d=1452181586
Shame about the smaller than Prius electric motor, I like my 470Nm's off the line :)
oldtamiyaphile 01-07-2016 09:55 PM
Hyundai Motor Senior Vice President Lee Ki-sang said the compact car, named the IONIQ, achieved fuel economy of 22.4 kms per litre, or 52.7 miles per gallon, in Korea. The latest Prius has not been launched in Korea, but Lee said the IONIQ would beat it for fuel economy in the United States and South Korea.
Also being a DCT this is likely going to be a Honda IMA style hybrid, it won't be able to move under EV power alone.
RedDevil 01-08-2016 02:48 AM
That was what Toyota keeps saying about the Insight.
My Insight moves under EV power alone just fine. The engine turns over all right but it uses no fuel and it has a special VTEC camshaft to stop the flow of gases so the cats won't be cooled by unburnt air.
As the IMA battery and motor are small it can just provide enough power to maintain speed in the city. But that still is pure EV usage.
The IMA system excels in killing CVT lag; one short burst of motor power to speed up the CVT drums provides instant acceleration.
I guess the Ioniq will use the motor to power or regenerate from one axle in the DCT gearbox while the engine powers the other axle, just like the new Fit Hybrid does.
But Honda suffered reliability problems with that DCT system so the new Fit Hybrid has not been sold outside of Japan yet.
I hope Hyundai does a better job with it.
oldtamiyaphile 01-08-2016 04:04 AM
I mean move a bit more literally, like moving it out of the driveway so I can get another car out. I think Hondas always accelerate from a stop with the ICE running? I did drive a HCH, I don't remember what it did.
If the IONIQ is like that, it's no deal for me personally, although if it has a tow rating that might make the decision difficult, no towing (legally) is a big draw back to the usefulness of the Prius for me.
RedDevil 01-08-2016 05:26 AM
It won't do EV mode below 15 km/h, which is when the CVT clutch slips because the revs would otherwise sink too low even in its lowest ratio.
Which is a pity, as in EV mode the motor could theoretically turn the engine over at very low RPM, no harm done.
But if you'd hit the accelerator then the clutch should start slipping to allow the engine to rev to be fired again, and that transition would probably not be smooth enough for Honda to deem it acceptable.
The plus is that it will do AutoStop (engine stall) rolling when braking very lightly below 15 km/h.
The clutch will fully disengage until you release the brake pedal which causes a restart.
I can make it coast for 50 meters or so, slowly advancing to a red light.
I may some day even add a brake light switch to engage that mode without braking at all for longer coasts :)
It does not use EV mode in reverse either.
It will use EV mode at high speeds and very light throttle (I used it even at 140 km/h) but that's just a lightly augmented coast.
10 kW is not enough to maintain speed at those speeds :)
In absolute terms fuel usage is still low at low speeds, even if it does not use EV mode. A stop and go traffic jam does hurt economy somewhat, but nowhere near what it would be with a non hybrid car.
MetroMPG 01-14-2016 01:39 PM
1 Attachment(s)
I'm sure it will have a real EV mode.
The Sonata hybrid and PHEV both use a fixed ratio, stepped-gears transmission, and have EV only operation.
More pics are out, plus a video:
http://ecomodder.com/forum/attachmen...1&d=1452796746
http://www.youtube.com/watch?v=R3PvFXykMN0
RedDevil 01-14-2016 02:55 PM
I read today that it can do 120 km/h in EV mode.
My Insight will only maintain 50 km/h in real EV mode, and just for a short while.
MetroMPG 01-14-2016 04:35 PM
I will perpetually disagree that Honda's IMA has a "real EV mode".
If the ICE is spinnin', it ain't EV! :p
MetroMPG 01-14-2016 04:58 PM
Ha!! I've done that (old car, engine died in the middle of an intersection). Can't do it on newer cars unless you bypass the clutch safety switch!
RedDevil 01-14-2016 05:59 PM
I used to move my old Civic on the starter motor every once in a while as my driving instructor gave me that tip to move the car away from danger when it won't start, and even mailed an auto mag where the reporter pushed his misfiring car off a busy highway while the starter motor could apparently have solved that for him.
I stopped doing that when the starter motor mount broke and the motor was dangling down in the engine bay hanging on its power cable... Apparently the stresses on the motor mount were too big.
And Darin, I could not disagree more.
Who cares if the pistons move as long as it uses no fuel it is a pure EV. I can see it uses no fuel, the UltraGauge tells me so. It needs to move so it can resume operation smoothly when EV mode ends. It would be able to maintain EV mode slightly longer if the pistons did not move but it would also need to keep a bigger reserve to rerev the engine when EV mode ends.
By saying that the IMA system has no true EV capability Toyota implies that it cannot move under electic power alone, but it does that just fine. That, and the Prius' more optimistic EPA ratings, killed the Insight...
oldtamiyaphile 01-15-2016 04:06 AM
https://www.youtube.com/watch?v=G4MwEgpbZBg
MetroMPG 01-15-2016 09:14 AM
I care! It's inefficient.
it is a pure EV.
I think the disagreement here is over the adjectives. Of course IMA has an EV mode. But it's neither "pure" nor "full" if it spins the ICE to do it and can't move the car from a stop.
RedDevil 01-15-2016 12:49 PM
I meant definition wise of course. Even so, this was a design choice. It would never do much EV work anyway. Now they could eliminate the flywheel, extra clutch and alternator, saving both cost and weight. That more than makes up for the bit of extra friction. It has the special valve mode anyway to teduce drag and prevent blowing cold air into the cats.
Rotating the gearbox is fine, the clutch plates fine, but pistons no, even if the valves stay shut? That is just mechanics.
Not using fuel is my definition of pure EV, and it applies.
Not full EV, never said so. I wish it would move from a start in EV mode! Honda missed out on that. I bet it could easily if they just let it happen. Ah well.
Zach 01-15-2016 02:39 PM
Originally Posted by MetroMPG (Post 504715)
In the video it focused on the rear slats, sorry for the FE newb question, what do those do to help aerodynamics?
http://icdn5.digitaltrends.com/image...-970x647-c.jpg
Xist 01-16-2016 08:15 PM
I feel like I am missing a message. How do you move a car using the starter? Clutch interlock, starting a car without holding down the clutch? When my brother was a kid, my sister left him in the car when she ran inside the house. My brother kept turning the key and the car dented the garage door.
With my Prelude, I once wondered what happened when I held down the accelerator instead of the clutch. Funny how it simultaneously started and started moving. Then my clutch went out and I needed to figure out how to get it to my mechanic.
I cannot do that with my Civic, though.
Zach, I apologize, but I do not know what you mean by rear slats.
cRiPpLe_rOoStEr 01-16-2016 08:53 PM
If it wasn't possible, how do you think GM would have used that BAS-Hybrid setup? :D
oldtamiyaphile 01-16-2016 10:00 PM
Clutch interlocks are easily disabled though. My Jeep is designed to start in gear, you just have to pull the fuse marked 'off road'.
Vman455 01-17-2016 01:04 AM
My Toyota pickup had a big button on the left side of the dash marked 'CLUTCH START CANCEL.'
RedDevil 01-17-2016 03:34 AM
It takes a manual, at least I never tried to do this with an auto gearbox.
Press the clutch, select first gear, release the clutch, start.
Do not touch any pedal when starting, and certainly not the accelerator pedal. That would only choke the engine or make the car jump forward when it does fire after all.
In a life and death scenario you can also use second to make a quicker getaway, but it puts larger stresses on the components.
