I hate the way this forum steals ideas!!
You all should be ashamed of yourselves!!
On an unrelated note Singing Dancing Boy Upset | The Onion - America's Finest News Source |
We are the Forum
Lower your shields and surrender your ships We will add your technological and biological distinctiveness to our own Your ideas will service us Resistance is futile |
Pick up trucks should be illegal.
Cars should be illegal!
Illegality should be illegal.
You know, the whole 1,200 rpm comment in the cylinder thread made me wonder. How many gears would a car need with a usable rpm range of 600ish rpm?? I am assuming a 600 idle and 1,200 red line.
I think semi trucks have a little more range than that. |
Depends, is it a European or an African Swallow?
- Depends on how much torque it makes. Jay Leno's Blastolene Special redlines at just 2,900 rpm. Six gears only, but over 3,000 ft lbs of torque. The Merlin-powered "Beast" uses a three-speed box. That engine revs to just 3k rpm. There's a Merlin-powered Rover that does 160 mph at 2,000 rpm. It could do 96 mph at 1,200 rpm in the same gear, then. If you have enough torque, shifting down to 600 rpm on each shift, I'd say ten or twelve gears might be enough... :D |
I can add a two speed axle to my Civic and a turbo that is spooled by 650 rpm. We can make this work.
it depends on weight too, the boss hoss has 1 gear, no complaints, easy 11 second 1/4 mile. more gears is an option.
