I have begun
My 1st tank sense joining here i tried to drive my normal conservative manor. Monday was my 1st day on this full tank to start to employee some of the driving techniques I've learned the past few weeks sense I've joined, it was kind of fun over my typical commute. I've slowed down from 5 over to the PSL, drafted a couple semi's on the freeway this the AM, starting to learn the minimal speed/engine load I can get the trans to up shift, slipped into neutral down some hills for my surface street commute home. It'll be 2 weeks till my next fill up, we'll see:)
Looking to get my fuel log to show + instead of my current - |
cool. keep me informed. i was hitting 56/57 this morning. only 53/54 on the way home with a cross wind. just installed a rear wing. and was hoping for better. if it doesn't work, i can scratch off another on the list and it was free.
metro,
yes it is, I keep track of every tank, seriously 95% of my miles are to/from work, same route every day and my mileage is pretty constant, if it drops 1 mpg I can usually contribute it to my driving. I plan to get a scangage, need to budget a couple repairs first. |
i have an ultragauge and love it.
Worked on my driving technique this last tank, 1.2 mpg increase over previous tank. Eco driving is starting to set in without thinking about it as much. A bit more practice and maybe I can get it up from 15+ closer to 16mpg.
Well done - technique is the biggest mod you can make :D
Please post what works best for you and (if you know) why. :thumbup: |
