I lost some power somewhere... anyone have a guess where?
Since I am paying close attention to speed, RPM and vacuum level, I noticed something disturbing in the last couple days.
I seem to have lost about 10 average MPH when maintaining the vac gauge at 10. I don't know if I am making less power in the engine, or if it is getting sapped away by one form of drag or another, but I can definitely see the change in speed at that throttle position as compared to a couple days earlier. I can only identify 3 things that have changed about the time this started: 1. I got the new wheels and tires, same size as before. 2. It got significantly cooler out. 3. It has been somewhat more windy. 1 is possibility, I guess, if I have increased my rolling resistance -- but 10 MPH worth? That would be depressing. The old tires were not significantly worn, just dryrotted, so it is not like I was running tread-less before. 2 seems like it should create *more* power, with an accompanying drop in efficiency, all else being equal, but maybe I am thinking of that wrong. 3 is a good bet, but I am noticing the power loss pretty consistently regardless of the direction I am traveling. Of course, there is a 4, and that is "something else happened to break/degrade/go wrong about the time of these other changes", and I'm not sure what to look for there. Engine runs fine and vacuum is still 19 or 20 at idle. It is bugging me because when attempting to drive with load I am now cresting gentle rolling hills at 40mph or below on 55mph roads, which starts to get a little risky, imo. Any thoughts? |
New tires will add some resistance. The big killer is cold and wind. Ive been noticing that here too.
Cold air = more dense = more power needed to push through it = dropped speed while DWL
I've noticed it a bit in my VX as of late as well. |
wagonman76 -
CarloSW2 |
Anyway, yes, you're taking a triple hit! ;) |
Okay, gotcha.
So to my as of yet fictional data-gathering rig, in addition to OBD II, injector pulse rate (and derived MPG), rate of climb/descent, ambient temp and manifold vacuum data, I need to add barometric pressure and humidity. That's all do-able, eventually. The real pisser is a real-time way to measure wind speed and direction, subtracting out that generated by my own movement. Must be a way, I think they do this on sailboats... (Don't look for most of this before next spring, though, at the earliest.) |
I don't know about the powerband in a Geo Metro - never drove one - but... My Honda B16 motor is widely ridiculed as a "torqueless wonder". At 8000+ rpm it will propel my ride like a white hot comet, but "cresting a gentle hill" at even 3000 rpm will cause my engine to labor, and the speed to drop precipitously! The workaround is to simply drop back into 4th gear and gently build some revs... ;) Have you tried this? It will allow you to maintain your vehicle speed without laboring the motor - shouldn't affect FE too adversely - and retain your vacuum readings, yes? |
Now, when I am going up a hill and the revs are dropping to about 2k in 5th, I'll downshift to 4th, but keeping me vac up still leaves me going between 35 and 40 mph and not gaining any ground until I hit the crest. If I want to maintain speed up a hill I am going to need to give it some gas, one way or the other. I'll be able to experiment more when I get some of the stuff I ordered yesterday. I just filled up a few minutes ago, 49.6 MPG. Little disappointing, actually, considering how radically conservative I have been driving (I was hoping to be in the low 50's), but given other comments here about the effects of temp and wind, maybe I didn't do too badly. EDIT: I forgot to calc for a -.83% odometer error! I broke 50! Whoohoo! 50.05 MPG. |
ive noticed the same thing laitly too, seems i need bit less vacuum to maintain old speeds. im usualy between 15-17 in-hg on flat roads, those 1L must be working it to cruse at 10 in-hg :P
The weather changed here in my region and I already can tell my MPG's are going down.
Next mod = Block heater |
ummmm.... How does new tires translate into more rolling resistance. New tires have stiffer side walls and the belts are stiffer. This leads to to lesser deformation which has the same effect as hyperinflation and means less rolling resistance. Every time I get new tires my mileage goes up. Further proof of this is when new tires are tested for rolling resistance they use brand new tires not used ones.
In discussions with my father who used to work in designing tires for Firestone he confirmed that stiffer side walls and belts would lead to lower rolling resistance. In fact its the stiffness of the belts is what gives radial tires better performance and lower rolling resistance than ordinary tires. as for a drop in power and fuel economy any wind that is not a tail wind is going to require more power to travel the same speed. cars are designed to travel through the air forwards not sideways. |
I had a fierce headwind the other day, coupled with cooler temps. Didn't need the window down, but it was a real struggle to get/keep highway speeds. The dense air usually makes a bit more power without an FE sacrifice, but the cooler temps did it. IATs have dropped as well. I cruise at 60-70, which is 2500-3000 RPM. I keep it in 4th/TC locked, 19TPS -- build up some momentum (depending on the hill, maybe go up to 21TPS) and hold the throttle to bleed the speed. MPGs drop, but hills do that. I make it up on the next downhill (hopefully). Unless I get impatient, the TC won't budge. RH77 |
The upside of this is that I definitely noticed improved traction when driving in heavy rain, and I am probably going to be much happier this winter. http://www.tirerack.com/images/tires...ku25_ci1_l.jpg |
