Old 03-17-2008, 01:31 AM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Would a different heat range of spark plugs help FE?
I was just curious if changing plugs out to a different heat range would help or hurt FE?
I haven't seen this discussed or couldnt find anything with a search..
thanks.
Old 03-17-2008, 01:41 AM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
From what I understand, the heat range doesn't affect the sparks ability to ignite the fuel much, but more so affects the life of the plug, to cold and it will foul, to hot and the tip will get hot and cause pre-ignition.
you have to get mighty cold to be a super conductor, so I suspect that a slight rise in heat isn't going to prevent a spark from jumping, altho I have read about surface gap (like Bosch platinum +4 plugs) tend to be hotter, because the spark is traveling so close to the ceramic insulator, and absorbs some of the sparks heat, this was out of an SAE automotive engine efficiency book that I read years ago.
Old 03-17-2008, 01:54 AM   #3 (permalink)
EcoModding Minded
Chris D.'s Avatar
Those Bosch +4 were garbage in just about any way performance related,
I highly doubt I'd recommend those for FE.
I'm a fan of Denso, NGK and Champion myself..
Those gimmick plugs that cost $25 ea DO perform excellent...
Less weight in your wallet helps gas milage.
(read sarcastic) lol
Next go around, I'm shooting for indexing..
Old 03-17-2008, 08:03 AM   #4 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
There is a member here actually testing the pulstar plugs. Can't remember who though.
www.HyperKilometreur.com - Quand chaque goutte compte...
Wood stove radiant heat!??! bennelson Saving@Home 28 07-29-2010 11:39 AM
DIY - Spark Plug Indexing SVOboy DIY / How-to 40 05-21-2009 12:58 PM
Halo Spark Plugs DifferentPointofView EcoModding Central 1 01-28-2008 11:13 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
