I shifted into reverse by accident
So I was driving home today after a long day at work. Shifting between N, D and 2 as usual to maximize cruise and DFCO. I always knew it may eventually happen and it did today - I went into reverse going about 50km/h. To my surprise, nothing happened! It was only there for half a second before I realized it and shifted back into neutral, but the car didn't even make any kind of sound or hesitation. It was as if there was a protection mode and the car just continued to cruise.
This is a 1998 Toyota Corolla. Can anyone confirm that there is such a protection feature? |
zimagold -
I don't know but whewwwwwwwwww! The title of your thread made me fear the worst. Have you tested reverse since that happened? CarloSW2 |
Yeah, I think I got lucky. I was honestly quite surprised at the behavior. Haven't tried reverse yet....pulled straight into my garage after I got home. I'm heading out again in about 30 minutes, so I'll give it a good test. I did drive it about 20 minutes to get home after it happened, and the car was totally normal. Whew indeed!
I have shifted into reverse about 3 times doing the same thing since iv been hypermiling, It has not done anything to my car. The first time it did absolutely nothing weird, going about 5mph (8kph) , one time I did it going about 40mph (64.3kph) and the car jumped a bit but I put it in neutral and it worked just fine. Once I did again at about 40 (64.3kph) and the whole car cut off, I pulled over and it cranked right back up and drove perfectly fine... You will be fine :p BTW~ I reverse into my parking spot, All 3 times were no problem at all
One day, someone gave me a car.
The next day, on the way to get the title exchanged, he took the car back. He asked me to drive it to his house, stating some BS excuse. I told you that story so this one would make sense: As I pulled onto this guy's (paved) road, I accelerated to about 60 MPH, put the transmission into neutral, redlined the engine, and dropped it into reverse, stalling it instantly. (Not what I expected to happen.) Yeah, I don't think I've ever heard of anyone actually damaging their car by accidentally putting it into reverse, even on the old GM 2speed powerglide auto. Unfortunately, nothing happened to the car.. this was 5 years ago, the guy still drives it. |
Nobody should be accidentally shifting into reverse in an automatic car!
The shifter is designed to prevent it in every car I've driven: you don't need to press the button to move between drive and neutral. You just push the selector forward. But you do need to press it to get to reverse from N (or out of P). So... you shouldn't be pressing the button when the car's moving. Even the old column mounted shifters were designed to permit going to neutral safely: by pushing the lever away from you and upward (rather than pulling - the normal column motion), the neutral detent will stop it. One partial exception I know of: VW used to require you to press the button to get out of N back into drive; not sure if they've changed that. And some other vehicles may not have a detent at D when coming out of N; they may slip past it to D3 or below. You need to know how your car works before trying this stuff on the road! |
I swapped the ugly T-shifter in my auto '84 Subaru GL with the pistol stick from an XT and the lock-out button ALMOST matched perfectly, but was a little loose when catching. Shifted into reverse once at 40 when it jumped through N and I expected to see the transmission in the street, but I beat the bag out of the car for another 2 years before cancer took it.
Most if not all electrically controlled transmissions have a built in protection feature that will not allow it to shift into a certain gear. Also they have a delay when actually shifting to the gear of ~1 second +/-. This is to protect the tranny from serious damage but this is not say that you can not do serious damage to it if you try hard enough. In your case I bellieve you are ok.
I did it once accidentally. Killed the engine and lit up the dash instantly. Dropped it back into N, re-started, listened for funny noises, then babied it for the next few miles.
It's been 6 months and there was no funny stuff in the transmission pan when I changed the ATF 2 months ago. |
Hello -
Maybe dumb thing to say, but this safety feature ONLY applies to modern automatics, right? Manuals can still self-destruct at the whim of the driver, yes? I'm asking because I "like" to think of reverse as my last best hope for stopping in a situation where my brakes have failed. No tranny left, but won't fly over a cliff either. CarloSW2 |
Lots of new cars have a lockout on reverse or park at speeds above, say 5 mph. Hyundai takes it a step further on some cars by requiring brake application.
But yes, I've had a few "oops" moments in my driving life... 1. 1988 Plymouth Voyager V6. First year of driving. Left the fast food drive through dropped something on the floor (salt packet or something), then as I came back up, my arm caught the shifter and I popped the column into reverse. Speed was about 20 and it died instantly. I thought I killed it. Luckily it started right back up. -- then there was a stint with manuals... 2. Integra: Backing into the driveway, I've accidentally popped the lever into drive at ~5 mph. It jerks and kills the engine. The goal was to coast in Neutral and cut the engine, but went a bit too far. 3. In some rentals, it's easy to accidentally hit Park at low speeds. The PT Cruiser has a notorious shifter -- when coasting into a parking area, I generally pop it into Neut without pressing the shift button. The PT has often just gone straight to park. It makes a lot of clicking until another gear is selected or comes to a stop. Essentially, I'm not sure if there are any further lockouts to add... RH77 |
Several manuals (I've been told) have an inertia lockout on them. If you're going over a certain speed, something moves in the tranny to stop you from putting it into reverse, kind of like the 5th gear detent on older cars. (You can't go from 5 to R, you have to go to neutral (resting position) to release the detent.)
CFG83 - Yep, you can put it in reverse if your brakes fail. First, you'll spend more time fighting to get it in there at anything over 10 MPH than it would take you to jump... and second, you'll have to rev match your engine to the gear, as it's not synchronized. Use your e-brake. That's what it's there for. Generally, and I think in all electronically controlled transmissions that DON'T have a direct linkage to the internals of the transmission (some still do, for reverse and park), you can put the car in 1 or 2 on the shifter (whichever is lowest on your shifter) and floor it. You won't over rev the engine. In fact, you can drive around just plain and dandy, but you'll nearly redline every time the transmission shifts. I do this periodically in my wife's GP (Granny), and have done it in several Chrysler 4 speeds, among others, including Saturns and Hondas. |
Oh well, no damage done, but still curious as to whether electronic protection saved my car. I always thought hitting R while going at speed would be catastrophic, but it seems others have also done it without damage. Cheers, |
I've done this in my 05 Corolla and it didn't complain either. The shifter moves just fine between RND in both directions with no need to push in the button. The worst I did to my car was accidentally shifting from R to P instead of N. Made a horrifying crunching noise as the car came to a hard stop, but the trans has been fine since then (about a year or so ago).
When you put your car into park, you've essentially put it into another Neutral, except with a tab that engages a part of the transmission to prevent it from spinning.
That crunching noise that you heard was just that tab trying to engage the transmission. If it catches, it will either lock up your tires, stop you instantly, or break something in the transmission, all depending on outside affecting conditions. This is why you set your parking brake on hills in an auto. It's not to keep your car from rolling (nice thought, but no.) it's to keep your car from fully engaging the park tab, making it difficult for you to get it back out of park... (yeah, you've had those times.) |
I've shifted into reverse once accidentally when I was learning the stick with our old 85 Cherokee, 4 cyl, 4 speed, absolute cheapest model they made that year. It was going downhill on a gravel road, didn't hurt anything, the back wheels just started skidding for a few seconds till I realized what was going on. |
Not all automatics are eco-friendly. I don't remember what I rented (I've rented 5 cars in 10 weeks), but instead of using a button, it had the "move it over and up/down" type of shifter. You had to move the stick to the right and then up to engage Neutral, and then back over and down to engage Drive. Unfortunately, when moving it right and up into Neutral, it was easy to slide it right and up again into Reverse. Fortunately I was only going about 15 mph, and it didn't shift at all. (I got it back into Neutral quickly.)
I remember back in the 80's when a neighbor took me and my siblings to school along with her kids. She drove a early to mid 80's Mercury Grand Marquis. I can't remember the exact circumstance, but we had to take this alley about 1/4 mile. Maybe it was winter and she was using the lower gears to keep traction. Whatever it was, I remember the sound to this day of what I thought at the time was shearing teeth when she accidentally crammed it into reverse. This was also the same dipsh*t that got t-boned while making a left turn (to school), and the T-bone was on the rear passenger door where I was sitting. It was enough to spin us around in the snow/ice and mess up the door pretty good, but I wasn't really hurt. I didn't let school officials know that though. As far as they knew I wasn't feeling well and needed to go home. It worked like a charm. How did I get here from the original question? sorry...
You're right on the auto-floor shift action. Nearly all can be flipped without the button from R to D (even columns -- just a smack downward). N, D and D3 on mine has free motion, but the button is needed down to 2 and again to 1. If you start out in 1, it flips all the way up to N with no button. It's handy to just give it a flick to downshift, or out of 2. It makes a solid thump, so not so stealthy with passengers. Some columns, I'll admit, are a bear to negotiate. Fords are simple -- just push forward toward the dash and up, and it stops at neutral or D until you pull back (others might be the same). RH77 |
My Lumina is column-shift; it'll "push-up" from D to N. Reverse is still pull forward though - in this case, contrary to what was said earlier.
... which is normal (pull from N to D for column shift). The potential hazard there is if you shift from N into a forward gear that's too low for your current road speed.
My Escort's shifter reads P-R-N-OD-D-L. One time I had shifted into D for engine braking and forgot to put it back into OD. I was approaching a hill at a little over 40 mph and wanted to bump the trans out of OD so I pulled the shifter down a notch, not realizing it was already in D. Remember there's no 2 on the shifter so it went straight for first gear, which redlines at 38 mph. Some cars will simply not engage a gear if it will over-rev the engine, but apparently my Escort doesn't have this feature. I felt the trans reach for first gear and felt the car start to lurch, and I realized what happened and bumped the shifter back before the engine zinged right past the redline. I've forgotten to put the shifter back to OD from D many times but that's the only time I've ever done that.
In a related story, a manual equipped car is in the works. |
Chrysler hydraulic transmissions won't (that I know of) engage first gear at anything over a certain speed, since the gear is equipped with a "sprag" clutch, which allows it to freewheel any time there is no force on the input shaft.
