I think my GY6150 is burned out :(
I went from Phoenix to Kingman AZ and back again with about seven dollars in gas :)
but I think I killed my scoot :( I started to lose power about seven miles from home And had to push the last six so its in the shop I want to try a taller gear I think it will help with my top speed and reduce friction losses that and maybe make for a more reliable bike any body out there have any suggestions on how to make improvements on JMstar scooter I have already removed about forty pounds of metal and plastic and I have lo R tires Would a better pipe help or is that a waste of monies |
What speed/rpm were you at?
speed was 50/55mph and as for rpm I have no tack
killed my scoot
There are shops around the country that specialize in Chinese scooters. One such shop is enviromoto in Indianapolis. You can contact the owner jeremy@enviromoto.com He's always glad to help with your questions... Gabe
If this scoot is something that you use almost everyday, like mine, then I would suggest first trying various combination of roller/slider weights until you find the right mix to allow a speed that you are comfortable with. I would also invest in a tachometer so you know how hard your engine is working in relation to that speed. If you have one of the sport GY6 scoots, then you are in luck. I am currently working on replacing my "non-tached" gauges with a set of OEM gauges that include a tach. I'll let you know how that goes. Having instant feedback from the engine speed is a very basic need for tuning for economical riding.
Changing out your exhaust system might give you a weight savings but that's about it. The factory exhaust on these scooters is not very restrictive. Any performance boost is negligible. I've been there. Trust me. It's a lot for money for not a lot of return. (They are pretty though.) Also, in order to keep your scoot running right after installing an aftermarket exhaust, you'll have to enrich the carb jetting, which will allow more fuel to flow and, obviously, hurt your mileage. Did you try cranking the bike after you got it home? You may have just been experiencing heat soak. These little things rely only on the crank fan to keep them cool and keeping them cool is key to their longevity. I'm also toying around with the idea of ducting some cooling tubes which will blow air from the front of the bike onto the head. We'll see how that does. |
The old engine block was trashed.
A hose came loose from the valve cover and blew all my oil on to the road the piston welded to the cylinder wall. It’s a complete loss |
Sorry, but ...
EV CONVERSION TIME!!! (I'm kind of waiting for my bike to die for that reason) |
I have a new gy6 now
And yes I am on the thing every day I put about a hundred miles a week on my scooter |
Check into a replacement engine. It may take a while to locate but since your dead scooter is nearly new, you could sell one of the two scooters you would have.
Here is the tachometer install that I promised you.
ScootDawg Scooter Forum - Swapping out stock gauges - RESOLVED w/ pics |
