I traded a 2001 Audi a6 for a 2001 Suzuki Swift.
Like the title says, I traded my 200k mile a6 to my dad for a $500 01 Swift off Craigslist. My dad needed a car because his Mercedes s430 spun a bearing, and I lost my job and am doing food delivery. So I needed something with good gas mileage. My wife doesn't like the beat up little Swift, but it is growing on me. I used to think these were nothing cars, but this thing is actually a hoot to drive. I can't wait to get some stiffer springs and some 175 tires for this little sports delivery car lol. Anyways with aggressive driving I'm averaging 35mpg. And on a tank where I was using pulse and glide I was getting 48mpg on the fill up. High mpg is so easy on this compared to my old 89 vw fox I had a couple years ago.
I'm hoping with the help from this site I can make this a nice light weight sporty economy car. |
Wow - 4th post since 2014!
Congrats on the Swift. 2001 was the last year of that generation. (You do NOT want a "Swift+" clone of the Chevy Aveo). I assume since you mentioned pulse & glide that you got a manual? We've had a few members with these cars through the years that were able to get pretty respectable results out of them. What are your modding plans? PS: nice since you're in the south that you don't have to worry about tin-worm eating the front control arm mounts away. .. assuming it spent its life down there. |
Yeah there is no rust anywhere, but all the paint is faded and chipped, lots of dents.
As far as eco mods, probably just lowering and antenna delete. Maybe a engine kill switch in the shift nob. Most of my economy will be technique over mods. Most of my mods will actually hurt fuel mileage, bigger tires, more sounds deadening etc. My end goal is a sporty small car that I can actually afford the fuel for, plus using it for food delivery. |
Definitely do the kill switch and get some instrumentation in there. Makes all the difference.
Do an air dam too. Goes well with lowering. |
Yeah mines not the greatest shape, but still fun. I purchased a Bluetooth obd2 reader for my torque pro app, but the latency is about 1.5 seconds which makes it hard to use as a tachometer and vacuum gauge. I might have to just get a pillar gauge cluster for it. But first some tires, I'm not trusting my driving habits with these 155s and no abs. Heck even with what ever measly power that comes out of my 1.3 I still light up the tires if I have to pull into a busy road.
I also need to work on body roll. All my previous cars would just start to slip if I accelerated to quick on an onramp, this thing FEELS tippy, though it's probably not as bad as I think. It has the 6 way adjustable seat which suits about 2 inches too high in the lowest setting. I don't know yet how I'm going to solve that one. Good news is last fill up was 320 miles on 8 gallons while doing food delivery in town, so at least it's serving it's purchase purpose :) |
Bigger rims and/or tyres are heavier Wider tyres are heavier & cause more drag They also tend to cost more - unless the smaller size is uncommon & harder to get. (Had a look, small sizes are expensive in the US, and the choice is ...meagre) For economy, low unsprung weight is a bonus My summer tyres are 15" light alloys, 185, 3% oversized, yet despite their better rolling resistance rating, they barely match my FE on 14" steelies, 175, regular sized winter tyres ... |
I was thinking 185s on a 14 inch wheel, maybe 175 on The stock 13s. I want a little less stopping distance for emergency braking, this thing locks up the tires instantly.
On my 2000 Metro, I chopped the springs (twice -- first time wasn't enough), then deleted the roll bars. Quite happy with the better handling, lower weight, improved aero. Oh, and the looks. Oh, and it's a free mod. Win-win-win-win-win! For a sportier feel, these cars need a faster ratio steering rack, but I didn't have any luck finding if there's one available (from the Swift GT, for example). Quote:
Post some pics. I want to see this beat up little car. |
I don't know how to upload pictures on here.
When pulse and gliding I currently use the ignition switch, I just turn it to the acc position so my radio doesn't reset. I've noticed that the car responds better to restarting if I put it in gear while rolling BEFORE turning the key back to the on position. The only down fall is that the turn signals don't function on acc position. I might try a front lip spoiler but I tend to pull up to parking curbs. BTW how would removing the sway bars reduce roll? That seems counter intuitive. If cutting the springs give good results I might give it a wack. |
Cutting the springs firmed up the suspension noticeably - I took the sway bars off to improve the ride over uneven bumps after that.
HOWTO - Add pictures/photos/images in Ecomodder |
Well I blew a tire today, so a falken all season 175 is in its place, next weekend the other 3 tires will match.
Apparently I didn't have a single tire with more than 17psi :( Maybe I should have checked the tire pressures when I purchased my 500 dollar car lol. |
Air pressure has a lot to do with handling and stopping distances... first thing I notice when I get a low tire is my car will want to slide in that direction when cornering in the wet...
17 PSI!
Holy cow, pump those suckers up... 45 MPG here you come. :) |
PS: if you don't want to figure out the photo attachments, just send me one and I'll post it for you. darin@ecomodder.com
So the car broke down again today, but this time I have to tow it. I was pulling out into and intersection and the transmission popped out of gear and started grinding. I can't get the car to start in any gear. As so as I start to release the clutch there is a pop and the gear starts to grind. It does this in all gears including reverse. The shift linkage under the car looks fine. I hope I don't have to pull the transmission to solve this problem. Do you guys have any ideas? I can put it in gear no problem but it immediately pops out of gear when I start to release the clutch, even as I hold the shifter in place.
It was the CV axel. First time I had a CV axel act like then when it failed.
Huh!
I've never had a CV fail. Usually they give you lots of warning with clicking noises when the steering is turned sharp under load, or if there's a vibration in the driveline while driving. |
I know, that was what was so strange. There was no prior clicking, and when it gave out, it just made a gear teeth grinding sound, almost like a starter slip. But surely enough I set up a camera under the car and one half spins while the wheel stays still.
Curious where you're at with this now. And how do you like the swift? I've been looking for a small commuter and I don't want to sacrifice my 2001 GTI to the hypermiler life. It's too fun.
