EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   IAC valve?? (https://ecomodder.com/forum/showthread.php/iac-valve-19453.html)
globaltefl 11-11-2011 03:25 PM
IAC valve??
I have a 1988 Honda Civic. On cold starts the engine will race. After a few minutes, if I turn the key off and back on quickly before it dies the engine speed will drop. But sometimes it will die and I have to turn the key off and on sometimes several times before it will start. I have cleaned the IAC, but doesn't help.
TomO 11-11-2011 06:38 PM
Sounds like your Fast Idle Thermo Valve (FITV) needs cleaning and adjusting. Start there.
What model Civic do you have, and what maintenance has been done so far?
globaltefl 11-11-2011 06:46 PM
IAC valve??
I have the basic civic 1.5. I have cleaned the IAC and fixed the seals--could have been leaking. Seems to run better. How is the IAC different from the Fast Idle Thermo Valve (FITV) and how do you adjust it?
gone-ot 11-11-2011 07:03 PM
...here's a IAC troubleshooting video:
http://www.youtube.com/watch?v=oNO8GCN8jQA
