Idenifying the CTS Gas Pedal of the Toyota Recall
If you own a Toyota, you may want to investigate whether your vehicle has
the CTS-built gas pedal that is the cause for the concern that is being widely covered in the media right now. If so, here is some info that I hope will be of help. Affected Toyota vehicles: 2005-2010 Avalon 2009-2010 RAV4 2007-2010 Camry 2008-2010 Sequoia 2009-2010 Corolla 2005-2010 Tacoma 2008-2010 Highlander 2007-2010 Tundra 2009-2010 Matrix 2009-2010 Venza Unaffected vehicles: Sienna Solara Yaris 4Runner FJ Cruiser Land Cruiser 2004-2009 Prius -- but still subject to the Floor Mat recall 2010 Prius Here is some hard data, photographs and discussion, on the CTS gas pedals that have been identified as the probable source of the concern. http://tuneyfish.com/blog/cts-pedal-denso.jpg From this article at tuneyfish.com which has more detail on telling the difference between the affected CTS pedals and the unaffected Denso pedal also used by Toyota. Here is a statement from the CTS corporation on the matter. And some details on how the gas pedals are designed. Many thanks to the good folks at tuneyfish.com for this info. (I also posted this at PRIUSchat and CleanMPG. I'm hoping that I haven't broken a forum rule or etiquette by posting here as well.) |
TBH - If Toyota is having these problems with this company over such a wide range of MY and vehicle models, why bother even working with them to fix the problem and install new pedal assemblies that (based on track record) will likely fail again?
If it were my business, I'd more likely be taking this company for a ride to pay the bill for installation of a non-fail Denso unit in every recalled vehicle. As far as I'm concerned, CTS has sullied their company image with unreliability on this scale, and shouldn't be getting off with "we'll redesign the parts". Nah, not even close, pal. |
And there's more:
First some additional analysis or the pedals themselves from The Truth About Cars: [I]"On initial observation, it appears that the CTS may be perceived as being the more solidly engineered/built unit, in that the pedal pivots on a traditional and solid steel axle whose bearings are brass or bronze sleeves. The Denso’s whole pivot and bearing surfaces are relatively flimsy-feeling plastic. But that can be deceptive, and we’re not qualified to judge properly if it is indeed inferior or superior. But according to our sources, the Denso unit will likely be recalled too. So the question that goes beyond the analysis of these e-pedals is this: are these units really the full source of the problem, or are they scape goats for an electronics and/or software glitch? Pictures and tear down examination and analysis follows..." in the full article. And there are other vehicle manufacturer and Canadian connections: [I]"Maker of Toyota gas pedal ramping up production to meet replacement demand By Kristine Owram (CP) – 3 days ago "TORONTO — The fact that a faulty accelerator implicated in a massive recall of Toyota vehicles was manufactured in Canada will have a negligible impact on the Canadian auto parts industry, says the head of an association representing suppliers..." "CTS also makes pedals for Honda Motor Co., Mitsubishi Motors, Nissan Motor Co. and Ford Motor Co., but the company said pedals made for those manufacturers don't have the same design. Still, Ford on Thursday halted production of some full-sized commercial vehicles in China because they contain CTS gas pedals..." Full Canadian Press article here. |
Hm. After reading that, it looks as though Toyota went to a bunch of trouble to redesign a piece of crap into a polished piece of crap with a different type of sensor.
What's so bad about using a standard pot-switch on the accelerator pedal, and forcing the ECU's programming to match that with the TB? I just don't understand why car makers feel like things need to be complicated to work. |
Basically, all the US built Toyotas are being recalled while all the ones built in Japan are safe.
...and, yes, my Vibe is affected by this whole mess! |
Lets just not jump the gun until all the dust has settled. (gee that's a lot of idioms for such a short sentence!)
Fly-by-wire was never high on my list of "good" ideas, honestly. |
A final installment:
The possible negative effects on consumers and investors not only stretches from North America to Asia, but to Europe as well. There are possible further recalls in France, and subsidiary effects extending to the Czech Republic. At this point it is safe to say that this is as much or more an issue for the CTS Corporation as it is for Toyota. In France, Reuters reports that Renault has this to say: "PARIS, Feb 1 (Reuters) - Renault does not share common parts with Toyota, the world no. 1 automaker fighting to salvage its reputation after a massive safety recall, a spokeswoman for the French carmaker said on Monday. "'Renault vehicles use neither the same pedals, nor the same parts as those of Toyota,' the spokeswoman said in a statement." However, Peugeot and Citroen may not be so lucky: "Peugeot and Citroen have models that are potentially the same car as the Toyota Aygo which is among eight of the brand’s models being recalled over potentially faulty accelerator pedals. "The Aygo, 107 and C1 models have been developed by the French and Japanese car firms and are built on the same production line at a plant in the Czech Republic as part of a joint venture. "A total of 1.8 million Toyotas in Europe are expected to be involved in one of the largest recalls in recent years. "However, while the Aygo uses an electronically-controlled accelerator pedal that is at the centre of the recall issue, the French brands only used this pedal in models fitted with stability control systems (ESP) or automatic gearboxes." Full story in the Irish Times |
This recall is spreading like the black plague did in Europe. Soon its going to be easier to say which countires are unaffected. It is fer certain the pedals fault. Now some Toyota's ARENT moving at all. Yep. Pedal. The pedal manufacturer has officially soiled Toyota's reputation. Consumer Reports has actually removed its reccomendation of the 8 Toyota's affected.
The 2009/2010 Vibe is indeed also affected. Makes me wonder about the older Toyota's, like 2nd gen Prius, previous Corolla, current/previous Camry, etc... arent affected. |
I remember the time I was driving in a strange city (Very Strange - SLS :) and the gas pedal on my '81 Celica felt different. It got somewhat better, and next time I had a chance to look, I saw that the pedal had fallen off, and I was using the mechanical lever it had been pressing on. It didn't warrant fixing.
Christ -
CarloSW2 |
Exactly the opposite there. |
Good analysis of both pedals by a third party (impartial AFAIK). They took apart both and reviewed the flaws in the CTS pedal.
Why Toyota Must Replace Flawed CTS Gas Pedal With Superior Denso Pedal | The Truth About Cars |
...and whats wrong with just using a damn cable?
Drive by wire allows the manufacturers to control more things behind the scenes. This gives the benefits of improved emissions, and better mileage.
...it's simple automotive economics (damn bean counters):
* 15% of $1 cable = 15’ * 15% of $10 plastic assembly = $1.50 ...remember, it's profit to them, not necessarily cost to you, that rules! |
Christ -
At this point it's a mystery to solve for me. There are so many questions : - What is the history of the CTS pedal? There must be an evolution of design that moved through "the system" to end up where it is now. They have already changed the type of plastic to deal with the problem in pre-existing iterations, so *someone* must have concluded that it was "good enough" in it's current form. - Are there other non-Toyota pedals that are similar in design? - Is the pedal "more complicated" because it allows for reuse of other drivetrain parts? It could be more complicated so as to drive down the *overall* cost and/or complexity of the drivetrain. - Was there a whistleblower trying to replace it? - What are the manufacturing costs for the different pedals? I heard the Denso and CTS pedals are interchangeable, but maybe the Denso costs X% more. The fact that it's in 60% of the cars Toyota sells implies that they were achieving a huge economy of scale. - What is the best pedal design out there, both "modern" (drive-by-wire) and traditional (i.e. throttle cable)? - If the CTS pedal was designed by Japanese Toyota engineers, will they commit Seppuku to make up for their mistake? CarloSW2 |
Well, I doubt they'll violently kill themselves, but you may hear about a few resignations, nonetheless.
I don't believe that either the Denso or the CTS design is superior, really, because DBW is a relatively simple concept that many people try to make seem like some outlandishly complex undertaking. RC cars have been doing exactly this for years, except with radio instead of direct wire control. The differences between the pot/stepper setup of an RC car and the way it could be implemented on a DBW system is basically all in the programming. The DBW system would have to have more than one input to determine optimum stepper setting for the throttle, but that has nothing to do with the most simplistic "volume control" pedal there could be. Remember my Mantra - Engineers do it on paper - in 2D. Ever tried to make a 2D object exist and function in 3D space? Real designers do it in real life, in real time, with real parts. When something doesn't work, we document it, figure out why, and correct it. Sure, it costs a little more up front, but the end result is a part that doesn't fail, kill someone, and cause a 80 million vehicle recall. Isn't that ultimately what we're after? |
Old Tele man -
(I think luvit beat me to it) Quote:
CarloSW2 |
* It's manufacturing cost is $15 * It's retail cost is $120... 700% profit :eek: That's a lot of beans... No, thats a lot of bull****. That wouldn't be CTS, that would be Toyota being avaricious assholes. |
I do, however, try to negotiate prices in my favor no matter where I am (as long as it's applicable. You can't really negotiate the cost of a candy bar in a retail grocery store, get me?) |
Christ -
My Dad was telling me how 747s and DC10s were some of the first fly-by-wire systems. There was no point in "fly-by-cable" because the planes were too big. A human wasn't physically strong enough to move the control surfaces with brute strength. However, they do have backup systems to allow the pilots to control the plane in even of systems failure. Little propellers pop out that are attached to generators. They allow the pilot to move the control surfaces with electric motors. Maybe Toyota forgot to add the little propeller-motors to their cars, :rolleyes: . CarloSW2 |
Carlos -
If you can get that information, I'll read it. After you're jailed for uncovering some international conspiracy by our government to sell the entire economy of this country to the Japanese. Have fun with that. :thumbup: Obviously, I'm kidding. Japan can't afford our debt. |
Christ -
Crush Toyota Sales ... ONE PEDAL AT A TIME!!! Remember, you heard it here first, :p . Overall, I don't know, I just have a vivid imagination. Is that a spider? AHHHHHH!, a spider! ... no wait, just a dust bunny ... nevermind. I'm just talking off the cuff. I could be wrong about everything. The thing is, we are looking at a flawed component. There have been warning signs going back to at least 2005, but no one has done anything substantive about it. And, Toyota's explanation doesn't add up. There's a long story here, and it would be neat (for me) to know it in full. CarloSW2 |
Hi Carlos,
Yes, and there are other terrible problems -- like Ford trucks bursting into flames sitting in the driveway (at night) -- I think it was a cruise control component overheating... |
The Audi 5000 had a UI incident, yes. Funny, though. It had a cable accelerator, IIRC. |
Neil -
Peugeot?s German Plans Hurt by Toyota Venture Recalls (Update1) - Bloomberg.com Quote:
CarloSW2 |
I don't buy it. CTS is just as responsible as Toyota, for not testing the design to ensure it's safe operation. How did QC not design a test for something like this? |
Hello -
Found this interesting article : http://www.autonews.com/apps/pbcs.dl...1/302019910/-1 Quote:
Christ -
CarloSW2 |
Hello -
My friend sent me this : Fixing Toyota's Recalled Pedals: The Video starring Doug the Master Technician — Autoblog It seems a different repair shim is used based on a gap measurement made by the mechanic. What does that mean? Does a bigger (or smaller?) shim mean the pedal is closer to sticking? Is this to compensate for divergent manufacturing tolerances? Or ... ??? CarloSW2 |
...'Sold by' and 'Made by'are two different sides of the same coin.
...seller bears the initial responsibility, while maker has secondary responsibility--legally. |
