EcoModder.com
-   -   Idle at 20mph (https://ecomodder.com/forum/showthread.php/idle-20mph-5559.html)
BrianAbington 10-15-2008 10:17 AM
Idle at 20mph
Theres a side road I usualy take on my way to work...minimal stops, and minimal traffic.
The speed limit is 25mph. I found yesterday that my car will hold 20mph when I take my foot off the gas. The engine drops back to idle (like Idle in drive at a stop light) It shifts to 2nd gear at about 15mph under slow accleration.
Is this a more efficent than keeping the throtle open to hold 25mph? Because the RPMS drop from like 1,500 to 800ish
The Atomic Ass 10-15-2008 10:21 AM
You'd have to test that one on your own, probably... But I can only imagine it helps.
95badbird 10-15-2008 10:57 AM
put it this way......anytime you are not touching the gas, you are using less.
BrianAbington 10-15-2008 06:52 PM
I figured that but I didn't know if vaccume pressure would affect this any.
whokilledthejams 10-15-2008 07:39 PM
An old roommate of mine had an old Chrysler M-Body with a 3-speed Torqueflite that could be coerced into idling along in 3rd, at around 25mph. Really nice in city driving.
cfg83 10-15-2008 09:05 PM
Binger -
I think you have found a comfortable sweet-spot for your Mirage. It's especially nice that the road's speed limit makes your speed look "normal". 20 MPH is probably the drop-dead-bottom-practically-idling 5th gear speed for my car too.
I wanted to find some gear ratios for your tranny, but all I could google were these URLs :
1991 Mitsubishi Mirage
Mitsubishi Mirage pictures 1991 models
CarloSW2
BrianAbington 10-15-2008 09:21 PM
theres a good sized following for these cars but most people swap 4G63T's in to them so no one knows what the stock specs are
NeilBlanchard 10-16-2008 12:42 PM
Hello,
For me, idling in 3rd or 4th gear (15-20mph) returns great mileage: 40-50mpg. Fifth gear is a little tougher to hold a speed on level ground at idle.
Throttle position is everything in FE. If I can hold the TPS to 19-20 (my xA displays 12TPS at idle when my foot is of the pedal), then my FE is much better than if it is at 21 and above.
