Just a couple things:
1. The cell phone charger thing is a flaky proposition at best, build the 7805 circuit:
http://ecomodder.com/forum/showthrea...html#post37049
2. Also, it MUST be connected to battery power so it is powered when the key is off, or in run, or in start. I have a few lighter outlets and one is off in start, the other is off when the key is off. That's no good for an mpguino, you will lose your tank trip or worse.
3. it said 8204 for the asian vsspulses per mile, should be 8208.
