EcoModder.com
-   -   If i remove my charcoal canister is that bad for FE? (https://ecomodder.com/forum/showthread.php/if-i-remove-my-charcoal-canister-bad-fe-9974.html)
95CHERJUST 09-03-2009 06:02 PM
95 jeep cherokee old technology not obd2.
No sensors are hooked up to my charcoal canister and i just got a vacuum leak from the canister iteself. Dealer doesnt sell them anymore and instead of strolling the yards can i just yank it and plug my vacuum ports on the intake manifold?
What do you guys recommend it basically is a place for fuel and emission fumes after the jeep is turned off right?
jamesqf 09-03-2009 06:35 PM
Isn't it supposed to catch evaporating fuel vapors when the engine is off, and store them so they can be sucked into the engine and burned when it's running? So wouldn't you expect some small decrease in fuel economy if you removed it?
I'd say pull it out, find the leak (if it's not in the hoses), and use some glue/sealant to plug it.
Formula413 09-03-2009 09:31 PM
Rockauto.com lists that part for ~$30, part # CP3045
some_other_dave 09-04-2009 02:13 PM
It should have zero effect on fuel economy. It will have a noticeable effect on emissions, though not those coming out of your tailpipe.
Patch the hole if you can, or get the replacement noted above.
-soD
mwebb 09-05-2009 11:23 PM
not a good idea to remove it -
if nothing else the evap system regulates pressure in side the fuel tank .
there are a few reasons why this is a good thing ,
imagine high pressure in a fuel tank
then
imagine partial vacuum in a fuel tank
yes
repair the system
bgd73 09-06-2009 06:46 PM
it decreases it dramatically, and if you find one line going back to the tank, there is even a danger to remove it...hot days and expansion keep happening while car is off, creating a pressurized system, the canister alleviates it. there is an upper atmosphere and a lower one in all vehicles, even the spot of the canister is einsteined, do not put it someplace else. also, check to see of one of the lines goes to thermal vacuum valve rather than straight to intake, and check vacuum pressure, you may be overdoing it with an error, canisters normally do not ask for much, it is a safety for the safety and for emissions that do not hinder, it can even add to power (utilizes system venting). Another note is the neutralizer of charcoal, the lines last forever with it, primitive air dryer, or whatever it is.:)
