EcoModder.com
-   Hybrids (https://ecomodder.com/forum/hybrids.html)
-   -   Ignition timing Prius (https://ecomodder.com/forum/showthread.php/ignition-timing-prius-23948.html)
kurzer 11-09-2012 04:16 PM
can i set the ignition timing in my prius a little earlier for the better fuel in Europe? my scangauge shows no difference between 91 and 95. so i think, the knock sensor is allready at its maximum and a mechanical change maybe a good idea.
Cobb 11-09-2012 06:55 PM
There are plenty of vvt piggy back controllers online, I am sure any one of those would let you adjust ignition as well as the vvt paramaters too. I dont think they use a dizzy that you can just twist to add or subtract a few degrees. :eek:
jakobnev 11-10-2012 04:38 AM
Even without a disty there should be a cam angle sensor that can be ajusted.
