EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   illegitimate fuel consumption (https://ecomodder.com/forum/showthread.php/illegitimate-fuel-consumption-26303.html)
Jack-Lee 07-02-2013 04:17 PM
Hello,
i install the MPGuino yesterday. It seems that all worked, but...
When i acellerate the fuelconsumption doesnt increased:confused:
The consuption raised only in lower gears..
What i do wrong?
t vago 07-02-2013 05:00 PM
What is your fuel injector input wire connected to?
Jack-Lee 07-02-2013 05:10 PM
I tested both: The + and - Wire to the injector
+wire : nothing to see on the display
-wire : works, but not correct.
When i accelerate, the value is not change at all.
I think the injector is a "Peak and Hold" type.. ?
t vago 07-02-2013 06:33 PM
It may be possible. Can you tell me what the coil resistance is, of your fuel injector?
Jack-Lee 07-03-2013 03:44 AM
Hello,
the resistence : 1.3Ohm
Its a Singleinjector
The Injectors from the stronger MPI Motor : 15,9Ohm
t vago 07-03-2013 07:23 AM
Originally Posted by Jack-Lee (Post 378917)
Hello,
This injector is very likely a peak-and-hold injector. They have not yet figured out how to get an MPGuino to work with these, I'm afraid.
That injector is very likely a normal injector.
Jack-Lee 07-03-2013 09:40 AM
Hello,
good.. i had two MPGuino. One from MTH and one vom "Wiseman".
The Guino from Wiseman should work with this "peak and hold" Injectors!
Fine :)
Quezacotl 07-04-2013 06:24 AM
Your setup works just fine. You do'nt need to select injector type.
Adjust the "Injector delay" in the menu. Try adjusting it up or down until the instant consumption is realistic.
If your inj delay is too big, then it loses data (=accelerations), and if too small, it goes nuts.
And every up-to-date MPGuino supports P&H injectors as far as i know.
Jack-Lee 07-04-2013 07:56 AM
Hi,
the consumption dont change when i accelerate...
And it is a peak and hold injector :D
I try it with the MPGuino from Wiseman (he has impliment the software solution from the Guino-Wiki)
t vago 07-04-2013 11:31 AM
You sure about that? The MPGuino wiki still has an advisory that states that peak-and-hold injectors are not yet supported.
