illegitimate fuel consumption
Hello,
i install the MPGuino yesterday. It seems that all worked, but... When i acellerate the fuelconsumption doesnt increased:confused: The consuption raised only in lower gears.. What i do wrong? |
What is your fuel injector input wire connected to?
I tested both: The + and - Wire to the injector
+wire : nothing to see on the display -wire : works, but not correct. When i accelerate, the value is not change at all. I think the injector is a "Peak and Hold" type.. ? |
Hello,
the resistence : 1.3Ohm Its a Singleinjector The Injectors from the stronger MPI Motor : 15,9Ohm |
Hello,
good.. i had two MPGuino. One from MTH and one vom "Wiseman". The Guino from Wiseman should work with this "peak and hold" Injectors! Fine :) |
Your setup works just fine. You do'nt need to select injector type.
Adjust the "Injector delay" in the menu. Try adjusting it up or down until the instant consumption is realistic. If your inj delay is too big, then it loses data (=accelerations), and if too small, it goes nuts. And every up-to-date MPGuino supports P&H injectors as far as i know. |
Hi,
the consumption dont change when i accelerate... And it is a peak and hold injector :D I try it with the MPGuino from Wiseman (he has impliment the software solution from the Guino-Wiki) |
I did not read the thread clearly. I was at work, and browsing the forums on spare time...
But that what i said was my own experiences and happened exactly like you said Lee. But since it's P&H injectors, i dont know. Quote:
Ok.. it doesnt work :(
So i could wait for my new Engine, or build a filter.. |
A filter might do it...
Is it possible to show the waveform being fed into the injector? |
Hi,
i had a old oszi, so i can messure it. |
Hi,
the Filter works fine! I build and installed it today. |
