iMovie Share Settings for 720p YouTube HD?
What are people using as their share settings? I've had a very frustrating several hours trying to get this done right.
Thanks |
YouTube works well with 16x9 hd video, as long as you start with the right settings in the first place.
On actual projects, I will shoot and edit in 720P (1280x720 - square pixels). I then output as an mpeg4 using H.264 compression, file sized at 1280x720 with a data rate of 4000kb/s. It looks very nice doing it like that, although H.264 is slower to encode. Play with a few data rates until you get something you think looks good. (I'm NOT using iMovie, but I hope that helps!) |
Oh, that's great! I think I had the data rate way too low. Thanks, Ben
