Improving the minicompressor
1 Attachment(s)
It had no airflow inside so I added a fan to it, also put a diode on the fan cables so it doesn't blow up if the compressor is hooked up with reverse polarity.
https://ecomodder.com/forum/attachme...1&d=1603641763 |
Needs some sort of heatsink on the compression portion
