EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Injector Connectors (https://ecomodder.com/forum/showthread.php/injector-connectors-17518.html)
alternativefuelconversion 05-24-2011 02:42 PM
Injector Connectors
I'm new to the forum, so I hope it's alright to post this kind of ad in here.
My company sells fuel injector connectors for attaching a custom wiring harness to your injectors. We have the EV1 style injectors in stock and most other styles available on a limited basis.
Male and female connectors, with pins and seals. $5.00
http://www.alternativefuelconversion..._connector.jpg
Connectors with high temp wires installed in your custom configuration (setup to read injector signal or setup to be able to disable injector, etc.) up to 6" wire leads. $10.00
http://www.alternativefuelconversion...tor_splice.jpg
Email us if you're interested. Or check out our website (under construction).
Alternative Fuel Conversions, Inc.
Thanks!
Mike Black
Owner
Norman OK
mike@alternativefuelconversions.com
winslet 06-17-2011 08:04 AM
Hey,
fuel injector connectors is good for wiring this is Ok if you use lots of power
RobbMeeX 06-17-2011 09:04 PM
Cool, perfect if I want to not cut into my harness!
caroli 09-04-2011 08:19 AM
Cool i'm in!! Do you have any reviews?
