injector signal location - 3.1 MPFI LH0
1 Attachment(s)
hello all
my car has a 3.1 MPFI GM engine (LH0) and I like to install my mpguino. where do I find the injector signal? I appreciate your help! my car: chevrolet beretta GT 1992 3.1 MPFI V6 automatic **EDIT: Which one should I take? C11? (see the picture) and for the VSS: B9 or B10? thanks! |
You've marked it right on that picture. That red mark with a "?" that's a good point to get injector signal for MPGuino.
1 Attachment(s)
*********BREAKING NEWS***************
it works!!! I took the injector signal from the ECM and the VSS from the cluster. Still in the calibration process. Thanks for your help!! |
Congrats! You'll love it like I do :)
the calibrating process is nearly finished, but I have issues with the mpguino. sometimes the display freeze.
maybe I need put resistors/diodes between the signals of the computer/dash/powersupply? I took the power from the cigarette lighter thanks for your help |
