Insight Clutch Wiring Question
I noticed that there are two clutch switches in the first gen Insight. The top is yellow and the bottom not.
In my Insight, the lower clutch switch is not wired into anything. The wires simply hang there. First Question: Where are the wires supposed to go? Second Question: When doing the clutch switch mod, do you use the top or lower clutch switch? Third Question: What are either of the switches for? Thanks! |
Can you post a picture? Sounds like something's wrong.
