Install vacuum gauge on Honda NX650 Dominator 1988.
I want to install vacuum gauge .
I see no space to install. I can not post pictures. I can not put links. I've been looking at different vacuum gauges and are great for space fairing . Is there a smaller vacuum gauge ? If I do not find I have to install it on the handlebars. |
Hi herberpower - I've changed your account so you can post links/photos now.
Be sure to put a very small restrictor between the intake and the gauge. Otherwise your gauge will fluxuate wildly, being a one cylinder engine.
Most automototive gauges are 2" |
Thank you MetroMPG and VARN
Here you can see the speedometer: http://i57.tinypic.com/2mpdana.jpg The holes had fairing speakers. the plastic was marred in a few weeks . I had thought to put the classic vacuum gauge 2 "( 52mm ) , like these : 52mm Calibrador Puntero medidor tabla Mesa vacío Leer de 0-30 in.Hg Vacuum Gauge | eBay Tim Vacuum Black Dial Face Mechanical Analogue Dash Board 52mm Gauge | eBay I have also seen these electronic gauges 2.5 " (60mm ) negro cara 2014.01 60mm calibre coche vacío, luz blanca, auto manómetro de vacío, metros del coche, barra 1.0/ap106 en Instrumentos de Motor en AliExpress.com | Alibaba Group 60mm defi avanzada serie cr calibre coche vacuómetro metro de auto negro cara en Instrumentos de Motor en AliExpress.com | Alibaba Group The problem is that there is no space . They are great to put on the fairing . I thought to put the vacuum gauge on the handlebars or . Add a dome to the fairing and put the vacuum gauge on the dome . the dome is like this or another model: http://i60.tinypic.com/314piev.jpg |
Consider a vacuum gauge from a brake bleeder, It can be set on top of the side of the tachometer.
http://i60.tinypic.com/fm7zt2.jpg Or this? http://i60.tinypic.com/2r72aad.jpg on top of the lid tachometer numbers four , five and six |
