Installed "winter" grill blockers on Fiesta
Heres mine! Made from Kydex using template...
I used little tabs at the top to tuck under the plate bracket, keep it in place... http://i102.photobucket.com/albums/m...DE598E9340.jpg And mounted...I kind of copied the new Ford style grill openings on the new models :) http://i102.photobucket.com/albums/m...DE4861F0C7.jpg I think I'll make another "summer only" version with a larger opening. Maybe 175% larger...? Rear wheel spats... http://i102.photobucket.com/albums/m...DE51D3C83B.jpg Trimmed to fit using velcro to keep them in place... Havent mounted them yet. http://i102.photobucket.com/albums/m...3CC642B8-1.jpg |
Looks great. I got some of that material from my step dad to play with. He said its pretty neat stuff!
How much did the material cost? |
Are you going top block the top one too?
We get this stuff thru work (aircraft manufacturing)...I don't think it's too pricey...?
I think aerodynamically, blocking the top grill will smooth things out a bit...? I've noticed the heat coming on sooner today with the block, but it's relatively mild today (2 Celsius ). I wouldn't want to close off any more than I have now. Big road trip coming up over the holidays...I'll have to monitor temps and mileage :) |
Received my pre-made ABS grille insert pieces today. Installed them at the post office parking lot (bolt on). Noticed that both coolant and oil temps ran slightly higher (good), but as A/C was on, was happily surprised that those temps rose no higher than they did (Ultragauge). Enough air flows through the non-grille areas of the front end that I am pleased. Hope that the OP finds his to be "good" in some similar manner. I have a "winter front" soon to be delivered that really closes off the heat exchangers. With a 1k road trip commencing tomorrow -- solo & towing -- I hope to find "the range" of using the grille block.
