EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Installing in metro, injector issue? (https://ecomodder.com/forum/showthread.php/installing-metro-injector-issue-7067.html)
Bendr 02-10-2009 01:19 AM
Hi folks,
I'm getting ready to put together and install the mpguino spiffie kit in my '95 4 door 4 cylinder geo metro.
In my research I've run into a few posts mentioning some sort of issue with hooking up the fuel injector at the end with the ECU on a metro, I couldn't find any detail about this in my searching, so now I'm asking before I start tearing it apart.
My question is this, Is there an issue? do I have to take wiring through the firewall and tap the injector, or can I get away with making it much simpler, and bring all the wiring to the ECU?
Thanks,
Ben
Coyote X 02-10-2009 02:15 AM
The ecu is a pain to get at under the dash. If you can get to it then it is fine to hook up there. I think most people would rather just run a wire out and hook up under the hood. It is a lot easier :)
Either way works fine though.
americasfuture2k 02-16-2009 09:17 PM
not a metro, but an aveo
i gathered everything i needed to start digging into the ecm connectors to grab the vss and inj low wires. got to the car and saw how much if a PIA it would be and decided going after the end source would be much much easier. took me a lot less time to get the correct wires that way than is would have digging through the ECM wire bundle.
Bendr 02-17-2009 12:41 AM
Thanks for the help guys! I guess I'll take a look at the ecu, and then decide... :)
Unfortunately though, I ran my Metro into a tree, so assembling and installing the MPGuino , will have to be delayed further, until I can put the front end back together, and have a drivable vehicle...
Thanks!
