EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   "Instant" values bounce around? (https://ecomodder.com/forum/showthread.php/instant-values-bounce-around-10160.html)
nickdigger 09-13-2009 06:21 AM
Are mpguinos supposed to have stable Instant MPH, MPG, GPH, etc, readings, under steady driving conditions?
I'm still adding code to my mpguino & havent wired it into my car yet. For my testing, it's running on dcb's signal generator, which I thought should provide the most stable inputs possible, but my numbers are quite jumpy.
GPH ranges from 2.01 - 2.37, MPH is 93-100 (no, i'm not using the default #defines :) ), MPG is 35-48, RPM is 5300-5800. My Current & Tank data are all rock steady; the problem is only with Instant. Somebody's post about GPH going "0.12 0.12 0.12 0.15 0.12 0.12 ..." made me wonder if actual - rather than simulated - driving would produce stable figures.
I'm guessing the problem is due to vss & injector pulses landing on random sides of the 1/2-second sample window. (?)
SVOboy 09-13-2009 07:23 PM
What version of the software are you using?
nickdigger 09-13-2009 07:43 PM
0.75. I looked at 0.82 & didn't see a change in that part of the code.
SVOboy 09-13-2009 07:57 PM
In that case, I'm not sure. Mine was jerky on .69 but I heard about it being smoothed out, but I'm not sure for which update that was.
nickdigger 09-13-2009 07:59 PM
So is yours still jerky? What version?
SVOboy 09-13-2009 08:05 PM
Still jerky on .69. I'm not sure if I'll ever update it so unfortunately I can't tell you if it did indeed smooth out for my computer :p
