Instrumenting Prius brake problem
The good news is we are hearing stories that Toyota has a fix for the intermittent "brake problem" that is being applied at the factories since January. The bad news is I'd bought two, three axis accelerometers from Gulf Coast Data Concepts to study a problem I've never been able to reproduce.
Gulf Coast Data Concepts makes a USB interfaced, accelerometer and I bought the X6-2, Li-Poly powered, and X6-1A, AA powered units: http://www.gcdataconcepts.com/images/x6-2.jpg The don't include a 3-axis yaw but with two, located as far apart as possible, differential acceleration should give angular measurements, pick two of three:
http://hiwaay.net/~bzwilson/prius/Prius_brake_010.jpg The salient data points:
Any new tool takes a little time to master. Issues like drift, calibration, timestamps, and data handling can be investigated with Excel. But for operational use, I'll write some software to handle the mass of data. The device can sample 320 per second so the data can grow quite fast and Excel is so ... limited. Bob Wilson |
Friday morning in a drizzle, I finally experienced the brake anomaly while testing the accelerometer at 160 samples per second:
http://hiwaay.net/~bzwilson/prius/Prius_brake_030.jpg The Martin Road gate into Redstone Arsenal has speed bump just before the badge check. The first set gave a brief illusion of 'sliding', which is an all too common impression in Huntsville AL. I don't know why but ever since we moved here, every rain is followed by a 'slip and slide' road surface. In fact we lost our '91 Camry on a rain-slick, descending off-ramp. Had it been dry, I probably would have stopped instead of hitting the guy who was stopped at the bottom of the off ramp. This is a little more detailed view of the speed bump: http://hiwaay.net/~bzwilson/prius/Prius_brake_040.jpg Regardless, expanding the data around the first speed bump, I was surprised to find: http://hiwaay.net/~bzwilson/prius/Prius_brake_050.jpg I was surprised to see that slight speed increase after integrating the acceleration. Well below the threshold I might detect, the accelerometer data is fairly definitive. I would be happy to share the spreadsheet and data but at 3.6 MB, it is too large for the 900 KB quota. It can be uploaded from my PriusChat posting in the Technical Forum. I'll also upload it to the YahooGroup "Prius Technical Stuff." Bob Wilson |
Hi,
I had the brake patch, A0B, applied on Saturday. Fortunately, I found this narley pothole near the dog park before the patch: http://hiwaay.net/~bzwilson/prius/Prius_bump_240.jpg
I captured accelerometer data before and after the fix and the brake pause symptoms disappeared. Sunday morning we had a mix of snow and rain so I retested the speed bump ... no more brake pause. It looks to be a good fix. Bob Wilson |
Breaking news:
America announces a recall of two million miles of road which is causing braking problems for Toyota Prii. The fix will require some softwareing asphalt repairs to the roads. Toyota has not approved the repair plan yet pending review. To help pay for the fix, Corporations may actually have to pay taxes for their share of road use. In related news, God is recalling 4 billion humans for repairs to their brains. A programming glitch causes them to destroy the planet that gives them life. |
LOL! I wished I'd thought of it first. Reposted with full attribution. Moderators moved it ... darn it.
Bob Wilson |
Bob - thanks again for a quality post.
...and Marcus for telling it like it is! |
