Interesting article: 110 mpg bio-d motorcycle conversion
I like this guy's attitude: "What is the most efficient method of transportation available to me, the consumer? After a lot of research, I found the answer: I'd have to build it."
Green Machine What happened when one Tucsonan set out to create a super-efficient biodiesel motorcycle From The Tuscon Weekly http://www.tucsonweekly.com/binary/1...urr-25120.jpeg This 2000 Royal Enfield made a good conversion platform because the motor and transmission aren't integral (making for easier mix 'n' match), and the frame design leaves TONS of room to work and mount a mill that didn't come OEM. Quote:
Tucson Weekly : Currents : Green Machine He's using |
Interesting article.
I also read about another guy over in England who did almost the exact same thing converting the same model of cycle to diesel! Almost identical projects! |
I wonder if it would be easy to convert a URAL to run on diesel? Their prices for new have gone up recently, but for a motorcycle that comes with a side car (some models, the side car wheel is powered), it is hard to beat.
If the side car is 'easily' detached (as in, putting it on for a weekend would be less work than hooking up a trailer), then family, groceries, etc can be transported with it attached. LDJ |
Back from the dead...
In the Tucson article he says: Quote:
Do Veypor computers work on diesels? Is he aware that no air/fuel mix flows through diesel's intake ports? What is engine handling? Diesel water injection in the intake with the air/fuel mix? :confused: Cooler oil improves efficiency? :confused: I'd like to know how it all came out anyway. Weight, accel times, top speed, fuel econo, and last but not least, what kind of engine was it? |
There's not even a hint of any rideability experience in his comments- just starting the engine.
I think he might just be a guy who stuck a diesel into a motorcycle and got an interview. I'm not sure if he understands everything he is talking about. Though if you look up the conversion plenty of other people have done it with similar results-
10 Hp Diesel Engine Electric/Recoil Start for anyone interested in the idea this engine here might be an amazingly cheap route to convert a small enduro or any small bike to run on diesel. |
