Interesting Civic tech quirk
I have long noticed that my speedometer is about 2.5 MPH too fast, relative to roadside police radar readouts and more recently against my Ultra Gauge. I just stumbled across a possible explanation--though I am not sure. Using this calculator I estimated the difference in my car's stock wheel/tire combo with a 5th Gen Civic's stock wheel/tire combo. The difference in MPH readings is about 2.279 lower with my 14" wheels as opposed to the previous gen's smaller 13" wheels. I know the transmissions often just bolt onto one another, and I have learned that most gearing is about the same 5th/6th gen, but the final driven gear is often taller on the 5th gen cars. Did I figure this correctly?
California98Civic -
This may not apply to your-gen Civic, but Civic odometers have been incorrect in the recent past : Odo Uh-Oh: Honda extending warranties on 6 million cars Quote:
CarloSW2 |
My Odyssey was part of that mess. The speedometer is the usual 1-2% fast, but the odometer is more like 5% fast. They're not the same, which makes it even more sneaky.
I have the 175-70-13 tires and my speedo reads about 2.5% fast. That sounds about the same as yours, but we have different tire sizes. |
Right. 65 vs 70 sidewall almost covers the difference. I always assumed the 14's would have a close-to-accurate speedometer due to the slightly bigger tire.
Are you reading the speedometer mph or odometer miles? They're not always the same. |
Yep found the same thing with Google and hilly terrain.
The results are far better if you can find either flat ground or gently rolling hills. On the error in the speedo it may be a built in factor. Some makers side on the "reading higher than actual speed" aspect to help keep drivers legal and avoid any clams against them for speeding fines etc. it may also be a manufacturing error with the actual speed of the needle being accurate but the scale behind being slightly off if it is truly consistent at all speeds. Peter. |
