EcoModder.com
-   Alternative Transportation (https://ecomodder.com/forum/alternative-transportation.html)
-   -   Internal hub 3 speed? (https://ecomodder.com/forum/showthread.php/internal-hub-3-speed-3486.html)
Tony Raine 07-02-2008 01:33 PM
Heres the best pic i have right now.
http://i2.photobucket.com/albums/y46...e/IMG_1116.jpg
its an old huffy "internal hub" 3 speed. found it behind my fraternity house a couple years ago. apparently an alum bought it new and rode it all through college and donated it to the fraternity after he graduated. it has sat behind the house under a lean-to ever since. i'm amazed it survived, given the location. not shown is the sears speedometer that was on it!
i put on new tires/tubes (kinda hard to find), lubed it little, and rode it around for awhile before i lost interest. now i want to get it in like-new condition, since i think its a cool piece of history. i am familiar with bicycles, every one i've ever had was a yard sale or dumpster special that i had to fix to be able to ride (i also have a 20" columbia "cruiser" and royce union "bmx"-style).
my only issue is that rear hub. gears 1 and 3 are good, but it "skips" in 2. i've played with cable adjustment with no noticeable help, which makes me think there is something wrong inside. plus i just want to take it apart and put it back together again, guess its my nature.
is there hope? is this something i can get replacement parts for? i did some googling, but didn't really find what i am looking for.
thanks for the help!
metromizer 07-02-2008 04:00 PM
I have had three different 3 speed hub bikes. The first two are still around my 1sq mile work site somewhere... I gave one away ten years ago to a collegue (who since has retired) the other bike was last seen in some bike rack in front of one of our buildings a few years ago... hmmm...
But there's hope. I bought a Dahon folding bike 10 years ago that came with a 3 speed hub (so They were still being produced up 'til then at least). I would search for Dahon bike dealers in your area or look for one on Craig's list.
Lazarus 07-02-2008 04:32 PM
This might help. Sheldon Browns a good place to start.:)
NoCO2 07-02-2008 04:37 PM
I would love to start getting into collecting old classic bicycles that I find around and fixing them up as a hobby. I would take a different one for a ride each weekend on the Silver Comet trail or something, that might be fun!
ttoyoda 07-02-2008 05:56 PM
Danger Will Robinson
If you do take it apart, be EXTREMELY careful. The inside is a mess of special nuts and washers with tabs and internal slots. All these parts look very, very similar, and unless you have exact instructions, or you can document (I would make sketches, video or photos alone often don't show that critical detail between otherwise identical parts) the order and *orientation* of every piece, you will be doomed. I would suggest you keep each tiny piece in a seperate container, and label the containers to match your sketch.
A three speed hub is the only thing I ever took apart that I did not work when I got it back together. It was locked all the time.
The problem is probably due to some oil having dried up inside over the years and some ratchet or pawl is sticking. If I had to deal with it, I would de-lace the wheel, and soak the hub in Kroil for a week to see if that fixed it. I would only take it apart as a last resort unless I had first-rate (factory) documentation of every step of dis and re assembly.
Ryland 07-02-2008 06:22 PM
try soaking it in liquid wrench for a few days, 2nd gear is direct drive, 1st is under drive and 3rd is over drive, if 2nd isn't orking it is often because the oil go to thick, if it has an oil fill hole then you have a nice one, other wise you have to losen a dust cover over the bearings and fill it there with liquid wrench.
what brand of hub is it? I have a pile of sturmy archer hubs and wheels, a shimono 3 speed on my personal bike and I think I have a bendex that no longer works.
you can still get sturmy archer hubs new, along with the shimono 3 speed, maybe 4 speed and 7 speed, the 7 speed is awsome and massive.
skyl4rk 07-02-2008 08:05 PM
Try spraying WD40 into it. Shift it and turn it quite a bit. Then drain as much as possible and squirt white grease into it.
I have taken a Sturmey Archer 3 speed apart and it worked afterwards. It is best to do it on a workbench with good light. You need to be in top mental condition to do it as well.
AndrewJ 07-02-2008 10:11 PM
Those old Sturmey-Archer hubs are nearly indestructable. From what I understand a bit of "freewheeling" between gears is normal.
But yeah, what everyone else said, a solvent followed by fresh oil.
JamesLaugesen 07-02-2008 10:25 PM
Hubstripping.com can sometimes be a good resource.
Tony Raine 07-03-2008 09:21 AM
thanks for all the help everyone! i'll check and see what brand the hub is after i get off work today. i do have a parts washer at work, i could always soak the hub in that. taking the spokes off is pretty intimidating to me (well, not taking them off but putting them back on), but i'm sure its something i can google.
yup, that was easy
i love old bikes. i'd restore them all day if i could find enough people to buy them. too bad the scrap metal craze means i'll never find another one. but i do have a few 20" frames from when i was younger. one is a chrome kawasaki frame, stem and handlebars, with a front plastic "GT" rim. heck, i even have "license plates" for them. remember when some cereal (maybe kix?) had the metal bike plates for all 50 states? i have almost all 50. all of this stuff is stashed in my mom's barn (200 miles away), since i don't have a workshop of my own yet. next time i go visit i will take lots of pictures.
Ryland 07-03-2008 09:23 AM
These hubs are designed to be used with oil, not grease, greasing them can lead to problems like the free wheel sticking and a gear not working, the older ones always had a oil fill hole so you could change your hub oil, newer ones you have to pull the dust cap.
Tony Raine 07-03-2008 10:03 AM
as far as oil, should i use something like the "3-in-one" multipurpose oil ?(the stuff in the little metal can)
Tony Raine 07-07-2008 11:22 AM
alright, checked out the hub closer and its a shimano 3 speed WITH coaster brake. kinda odd since it has cable brakes as well. that opens a new can of worms. i took a coaster brake apart once and never was able to get it back together. so maybe i wont try to take it apart, just a good cleaning. oh yeah, and it has the fill plug.
Ryland 07-08-2008 12:02 AM
If you can't get it to work let me know, I've seen alot of 3 speed hubs and have always dreamed of finding one with coaster brakes.
Impulse 07-29-2008 07:43 PM
Honestly I would replace the cable, strecched cables cause all sorts of problems, and I have had this same problem with a 3 speed internal hub before and that is what fixed the problem. I know that they cause alot of problems on top normal and low normal derailleurs. Just my .2 cents!
motomerle 08-02-2008 11:07 PM
I saw some bike recently with a 7 speed internal rear hub
Ryland 08-03-2008 11:18 AM
I have a friend who put one of those on a really nice aluminum and carbon fiber bike, it's top range and bottom range was just slightly more then my 3 speed, it just had more range through the middle.
TrikeKid 08-09-2008 10:45 PM
Hey, I think I just picked up the women's version of that same bike! Actually, almost got injured a couple times riding my bike over to look at it, but that's a completely different thread.They are sweet bikes for sure, I picked this one up for my girlfriend to ride at college.
taredog 11-01-2009 05:45 PM
Wow. That looks just like the bike that was stolen off my porch in Sumter SC in 1974. I'd had it since 61 and put a lot of miles on it.
Mine had a Sturmey-Archer three speed hub with a coaster brake. And a speedometer.
Enjoy
UFO 10-22-2010 03:41 PM
I bet soaking that hub in biodiesel then re-lubing will get that thing working well. Biodiesel is the best solvent I've ever used, and it's non-toxic.
Grant-53 11-08-2010 10:55 PM
My 1967 Huffy has a Strumey Archer 3 spd hub and I successfully replaced some of the cracked gears with parts from another unit. The older books call for 30w non-detergent oil lubrication. White grease won't hurt them but the oil works better. Cable tension is critical too. I switched from stock 48/19T to 40/19T for stop and go city riding. The common S_A models were AW-1 and SW-1. I doubt you would need to take the spokes off unless they are damaged. Another bike I put together is a ladies' Huffy frame, 26" rear wheel with a Shimano 3spd coaster brake unit and a 20" plastic front wheel...very comfortable and responsive. Cogs from a derailleur cluster can be cut inside to fit an internal gear hub so that two gears can be mounted together. A derailleur can be fitted to shift between them for a six speed rear end. The rear gears should be 3 teeth apart and the front rings should be 4 teeth different. Example: 16/13T rear and 44/40T front.
The new 10 spd Shimano hub with disc brakes is something I'd like to try for an aero bike.
