Introducing my SuperPILOT - 50+% over EPA!
8 Attachment(s)
Hey all,
I've been a lurker for about 3 months now, but after my first 3 tanks, I'm getting my 2004 Honda Pilot (rated 15/21/17) to about 27mpg combined, so I decided to chime in. I average about 35% city 65% highway. I want to be able to hit 30mpg combined sometime, so I'd like some suggestions for CHEAP mods. I have some pics for y'all so you can see what I've done to get to where I am. My personal tip: ELECTRICAL TAPE + ZIPTIES ARE WONDERFUL. Cheap, waterproof, and won't ruin paint/plastic/metal. Aeromods I've done:
Fixing the nut behind the wheel:
I haven't done anything to the engine, so I need some suggestions there! Here's what I found about speed vs. mpg though:
Sucks that this is an auto tranny though... the torque converter is really hard to get locked up. I get a lot of wind noise around the A-pillars - does anyone have experience with turbulator tape or similar to modify airflow around there? How about at the back (around the trunk)? Suggestions please! :D |
Welcome to the site! Looks like you are well on your way to a great vehicle.
Some suggestions: *Maybe extend the front air dam down in front of the tires for a tire spat effect. This might make your air dam more worthwhile. *I would seal up the outer edges of your belly pan, so that the coroplast attaches to the bottom edge of the side panel/door. I fear that air is coming in from the side, which might cause some turbulence and maybe a parachute effect, effectively making the pan useless. Seal it up and you might see a better result. (Only a thought, you'll have to confirm.) *Kammback. You might be able to use the spoiler mounts to do it as well, so you won't have to make holes or even need tape. *I would definitely try the rear diffuser. You can even design it so it deflects air away from your hitch, so that the hitch becomes almost non-exisent, aerodynamically speaking. You could also just extend the belly pan all the way out to the point of the hitch. I have no advice for turbulator tape, but do a search here, I think there are a couple of threads that talk about it. Don't be surprised if you have to replace your starter sooner rather than later. All that EOCing will kill your starter. |
hi hliew88, impressive mods for a new member
also, if you added the panels under the body before you added the air dam, then youre going to see a smaller improvement than the same air dam on an unmodified vehicle |
I think there's a thread on tire spats and that topic on here in the last few months. Thinking of your factory dam only covering the inner edge of the tires, I had thought the shape of the airdam on the new silverado was designed for keeping air out of the wheel wells (I don't know if anyone else agrees with that though)
Welcome aboard! I always get excited with Ohioans joining!
Look forward to reading more and chiming in :) |
Welcome to ecomodder.
Looks like you've made a good start already :thumbup: Quote:
It's a vehicle with a (nearly) horizontal roofline, so a diffuser won't help there - and by itself may make the drag even worse. Though it's helping the belly pan to work, and eliminating the aft parachute effect which both help your mpg, the diffuser is possibly reducing some of what you gained. Old aerodynamics research showed diffusor angles should generally be rather small for drag reduction, like 2-5°, and 0° on horizontal roof lines (old station wagon style). Quote:
At best, I'd expect some cleaner separation of the air, which you might see as changes to dust and rain accumulation on the rear end, though it may not be apparent in your day-to-day fuel consumption. Quote:
Air dams (and bumpers) push out the air a bit further than where they end. This increases the apparent frontal area - even though they are within the original vehicle frontal area. It's OK if the airdam ends a few inches inboard. Same with your rear-wheel deflectors. They seem to be positioned too far outboard. Unless you add side skirts between the wheels, the air will flow out to the sides @ about a 15° angle - though a diffuser would suck the air more to the rear . The position and angle of the deflectors in front of the rear wheels needs to be chosen in relation to the air that hits them. They can be extended aft as vertical strakes on the inside of the rear wheels, separating dirty (wheel side) and clean (belly pan) air, the strakes can then be carried further aft as a diffuser side plate and/or inboard side of a rear wheel fairing. Quote:
Warm air intake. Keeping the air filter clean also helps - with OEM often being more efficient than K&N style filters. Pre-warming coolant or oil. Engine blanket - or some simple cardboard as some ecomodders are using. Quote:
Around 55mph is a nice speed for many cars as far as mpg goes. Quote:
Buying a fuel efficient car is the best mod to start with. I'm surprised it's still not high up on the ecomodder Mods & Tips pages :confused: The latest automatics - like the ZF 8-speed box (BMW / Jaguar / LR) - are good for FE though. Quote:
It actually works, even when using dimple tape - which is only a series of heat-formed holes made into a sturdy tape, making what looks like very small volcanoes, the holes being the crater :rolleyes: Doing it again I'd use zig-zag tape rather than dimpled tape. I put dimple tape along the A-pillar, quite close to the windshield (before the air is making it around the corner to the sides) and on the mirrors. The tape, though ridiculously thin, audibly reduced the A-pillar noise - very common on this car series . It altered the air flow over the side windows enough to affect the flow pattern of raindrops that'd get onto it, then stay on the upper front half of the side window and block vision. With the dimple tape, the raindrops became near-horizontal streaks and got carried aft with the airflow, restoring vision. Pics are restored in this message : http://ecomodder.com/forum/showthrea...tml#post323190 Quote:
See the link above for what I did @ the back end. Tape is simply too low to effectively alter the airflow here. The boundary layer will be too thick. I never saw any change in flow (rain, dust accumulation) pattern there - let alone in mpg :rolleyes: |
The Pilot's a nice enough vehicle, especially if you're at all outdoorsy or go in for adventure sports. But aerodynamically, you have already determined it's a dog's breakfast.
Your wheels don't permit much in the way of smoothie discs. I wonder if you could add bulgy skirts on the rear to close up some of those big buckets they're riding in? You have way more confidence in electrical tape than I. But if it works, hey. Go with what works. +1 on closing up the edges of your belly pan. Side skirts. Warm air intake on your car. Some guys do better with it, some without. Testing req'd, usually a nearly no-cost mod and easily reversible so you aren't committed. Not much else to do regarding weight reduction. You could take out carpet and stuff, but it's already a big boomy box - do you want echoes too? I don't think you have enough gains left to merit making it a noisier ride. I've read more than one project where the owner was able to install a clutch lockup switch that forced lockup at any speed. Usually they're able to do it without throwing a check engine light, which is key. You could do as well and come close to eliminating your torque converter losses; generally the TC is crucial only at stops and during initial acceleration, the tranny can shift without unlocking the TC, though in some instances the shift feels a bit harsher. Again, more research and testing required. Also reversible, especially if you install the switch in an existing knockout. You have a tough row to hoe. Taking a 17mpg combined EPA ride to 27mpg in the real world is really, really good. Getting another 10% to hit 30mpg...well, I'm glad it isn't me that's trying to do it. I'm rooting for you, but I'm glad it isn't me. |
Do you use the vehicle to tow stuff? If not, take that hitch out and save the weight and headache that is causes with the belly pan.
x1000 on finishing the belly pan and closing up the openings. With a full belly pan, you shouldn't need the air dam; if air is flowing smoothly under the car and not developing turbulence, you don't need to block it. Side skits could help keep air away from the leading edge of the back tire but a slopped spat could do the same. Looks up member "arcosine" and his build thread on aeromodding his Saturn SC...pay close attention to the treatments he makes to the front and back of the wheel wells. Great job so far! If you want to get "hard core" you could always change the gears in the rear. But that would cost double if you have a 4 wheel drive model... |
The other thing I notice is that most of the turbulence does come from underneath. In the rain I just see water coming up, whereas it seems to go straight off the top and sides. I pulled in the ends of my air dam! (see pics) What I did has the added benefit of going all the way back to the edge of the wheel well too. Win. Also pushed my rear wheel spats in about 2 inches or so. Quote:
I would get a warm air intake just by lifting that box up that contains the filter, right? Quote:
Nno way is the hitch coming off. My family does do some heavy towing at times (notice the big trailer connector hanging off). Plus it's so rusted that the bolts will never come loose! Tomorrow I'll try to close off the sides of the running board/belly pan transition with something black. Then maybe I'll take a run at 55mph and see what mpg I can get. Anyone have experience with how long starter motors last? |
5 Attachment(s)
Forgot the pictures!
