EcoModder.com
-   -   I've drastically changed my driving style and getting results! (https://ecomodder.com/forum/showthread.php/ive-drastically-changed-my-driving-style-getting-results-1250.html)
Chris D. 03-03-2008 01:19 AM
I've been documenting my achievments as I go on a Tacoma forum because Ihave a Tacoma..
On average I pulled 290 - 310 miles till the gas light comes on..
Once the gas lights comes on I have 2 gallons in reserve..
On my last tank I was at 372 miles just as the gas light came on.
I didn't have any other way to document this, so every few miles i shot a picture of the trip meter and gas guage..
I'd like to log this on here, but don't know where to go to do that..
anywho, heres where I'm at.
http://www.customtacos.com/forum/sho...d.php?t=108887
I'm trying my best..
SVOboy 03-03-2008 01:46 AM
Are you calculating the mileage when you fill up?
Chris D. 03-03-2008 01:49 AM
according to my first 2 pictures from that post, I pulled 26.76 mpg..
AndrewJ 03-03-2008 01:52 AM
Add a fuel log entry!!!!
:thumbup:
diesel_john 03-03-2008 02:02 AM
Chris do not get discouraged with the tacoma site. Your are making a difference over there, by your example.
i always let the fuel nozzle pop off and that's all. gasoline is so volitale that you can loose some if you over fill.
you can go to EM garage at the top of page and publish your fillup numbers.
do you have any way of a real time economy reading, it can really help.
for those who don't:
a vacuum gage has worked for a hundred years.
a 20 megaohm digital volt meter hooked to a front O2 sensor tells you when you are in closed loop. (if it's not warmed up, if you move the pedal too fast or too far, the computer will come out of closed loop) you may able to adjust the linkage on your cruise control so that it cannot open the throttle enough to kick the trans down all the time.
an accurate dwell meter on an injector will tell you the % of time its open.
roflwaffle 03-03-2008 02:04 AM
35mpg or bust. :thumbup:
Chris D. 03-03-2008 02:17 AM
Thanks for telling me where to go, I just did, I'm no longer a fuel log virgin :D:thumbup:
I'm not discouraged by anyone..
Its actually a great change according to what people are usually seeing on there.
I've at least raised awareness about it and got people thinking now. :eek:
I'll look into a vac guage asap, when I had my Shelby GLHS (turbocharged) I used to watch the boost guage all the time and got great results by staying out of the vac.. :thumbup:
I mite do somethign lame and get a boost guage 20vac/20boost just for looks..
They dont cost anything different than just a vac guage :)
So its a slight poser mod, but I do plan on turbocharging in the future..
H4MM3R 03-03-2008 02:26 PM
I've always wanted an GLHS.
NoCO2 03-03-2008 02:46 PM
Man, great work!
I really need a new car...now a pickup truck is almost doing better then me, NOT COOL!
Chris D. 03-03-2008 09:57 PM
I'm well past the 400 mile mark..
I'm at 410 and have at least a gas needles width away from the gas light comming on.
Hey NoCO2, I'm gonna smoke the camry by the next tank ;)
Copyright ©2000 - 2021, vBulletin Solutions Inc.
