EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Jeep Liberty Air Dam (https://ecomodder.com/forum/showthread.php/jeep-liberty-air-dam-16104.html)
Joenavy85 02-13-2011 01:57 PM
I'm trying to figure out how to attach an air dam to the front bumper of my liberty, but i'm not sure what the best place would be in order to keep it rigid. any ideas?
http://www.autotrucktoys.com/liberty.../M82206122.jpg
not my jeep, but looks the same, without the tow hooks
BamZipPow 02-13-2011 03:07 PM
Couldn't you just build some brackets to hang it off of the tow hook bolts? ;)
Joenavy85 02-13-2011 03:12 PM
i thought of that, but it would block the lower grill opening, i already have the upper grill about 70% blocked
Joenavy85 02-13-2011 03:17 PM
the openings look like this
Jeep Liberty Renegade 3.7 wallpaper # 03 of 15, Front, MY 2005, 1280x960
though i could leave an opening between the mounting points, and brace the air dam against the lip of the lower opening
BamZipPow 02-13-2011 03:50 PM
The brackets won't be that wide to block the lower opening...maybe 1" wide each? Some 1/8" steel flat bar would work... ;)
You could even remove the front hooks and just use those existing bolt points. ;)
You'll still need to brace the air dam so the air doesn't push it back or fold it over. What sort of materials are you planning to use? ;)
I guess if you git really creative, you could probably hook the top of the new air dam onto the hooks and then secure the bottom with some other brackets. Would make it easier to put on/take off... :D
Joenavy85 02-13-2011 03:53 PM
i can get brackets made to extend down to the bottom of the air dam, i'm not sure yet what material i'll be using, right now i only have coroplast
BamZipPow 02-13-2011 03:55 PM
How far down are you looking to go? Do you do any off-roading in yer Jeep now?
Coroplast is fine but you'll need support behind it as it will fold over without the support.
My Toyota T-100 air dam mod... ;)
Joenavy85 02-13-2011 04:00 PM
i don't do much off-roading, only in the summer when i go camping. but if i mount the air dam on the tow hook points it will be relatively easy to remove.
Joenavy85 02-13-2011 04:47 PM
i can make a couple brackets out of some aluminum angle that would come straight down from the tow hook mounting points, at the bottom i could run a 1/8"x3/4" aluminum strip across and have 4 pieces of angle run back to the forward crossmember as bracing and then cover the front with coroplast. think that would work?
BamZipPow 02-13-2011 05:27 PM
Give a try and see. How much you looking to spend on this project? :D
Joenavy85 02-13-2011 05:56 PM
no more than around $50. i looked online for aluminum prices and they aren't too expensive, and i already have the coroplast, so that $ amount isn't going to be factored in. this style air dam will also make the front belly pan easier to attach, as well as deflecting the air past the suspension arms
BamZipPow 02-13-2011 09:34 PM
You might luck out with someone on craigslist who might have some metal scrap that might work fer yer project so you can keep costs down. Worth a peek... :D
Home Depot and Lowes has some pretty good prices on their metal stock... ;)
You might want to consider C channel stock instead of the flat bar and angle stock... ;)
t vago 02-13-2011 09:45 PM
Why not use 1/8 inch Lexan? That stuff cold-bends fairly easily, and is much stronger than coroplast.
Joenavy85 02-13-2011 10:08 PM
i'd prefer to stick with coroplast, easier to work with and cheaper
