"JUMPR" Compact Jump Start Battery
Anybody seen this new "Jumpr" product or have any thoughts? I would have to see this thing jump start a car in person before believing it is possible :confused:
Ooops, this one might belong in "The Unicorn Corral":eek: This Tiny Battery Will Charge Your Phone and Jumpstart a Car |
I would like to see is a load test (amps) along with the voltage, instead of just a voltage test.
Battery Cold Cranking Amps (CCA) for a gas motor is usually figured at 1 CCA per cu. inch. and diesels at 2 CCA per cu. inch of displacement. With more being better. This "Jumpr" would probably work under ideal conditions. How many tries you get at it if it doesn't start the first time though is another question... > |
I have seen them before recently I like the idea, Great for Hybrids which just need a strong 12v signal to get the HV batteries to start the engine. But I would never use it on another ICE only car because it would probably be one of the "OK we got one chance to jump this car" type of chargers.
It appears to be a Gimmick to me, but I bet you could start your RC car/plane with it.
I could charge my cell phone twice with a 6000mah battery pack. I call bull on this product and suspect its marketed to Woman, who generally do not understand the cars battery amperage or charge requirements. |
i've seen stuff like this pop up before..... and i just ran a calculation to be sure:
6000mAH(let's just call it 6 amp-hours) 12 amps for 1/2 hour 24 amps for 1/4 hour 48 amps for 1/8 hour 96 amps for 1/16 hour 192 amps for 1/32 hour (and to get it in the 300 range) 288 amps for 1/48 hour 1/48 hour is 1 minute, 15 seconds. that MIGHT be enough current to start your average car in most conditions, but from what i'm told of these units, you don't just hook them up and attempt to start, you let them sit connected for a few minutes before doing anything else. |
288 amps x 13v = 3744 watts to start a small car
I seriously doubt a 6 amp hour battery will put out 3744 watts worth of energy, that would equal 37 minutes of a 100w drain (3744 divided by 100) I may well be missing some figures in my simple math above so if you know why this jump starter stores more power then I have denoted please post your math or hypothesis. |
my black&decker booster pack(rated at 300 amps instantaneous) has a lead-acid 9AH battery in it... at a full charge, i've managed to turn over and fire a ford 4.6 with a VERY weak battery with it before, no intentional waiting with it hooked up to try and transfer as much current as possible before cranking.
with a 6AH unit..... i would certainly give it as much time as reasonable before attempting to crank to make sure that it could be done in a single cranking attempt, since i don't know how many other chances one would get with that capacity. |
I don't think these (like most) jump packs are meant to start a completely dead car. If you left the headlights on in a well maintained long enough that it just clicks the relay and not long enough to completely drain the battery - this will probably work. It would give just enough to get the vehicle to turn over.
Most vehicles don't need to crank a bunch to get started. |
My 395 cubic inch 22:1 compression diesel draws 350 amps when starting, but it does have a gear reduction starter.
The gear reduction starter is smaller, a lot lighter and draws a lot less power than a direct drive starter. If you dont have a gear reduction starter you might want to see if there is one made by some after market company. A gear reduction starter would be a good step towards an some type of alt delete or just making your car lighter with the light weight starter and smaller battery. |
You know Ive seen those gear reduction starters and often wonder if the net speed is the same if the load was too much or power too little to spin a direct drive 1:1 ratio starter.
I own a similar, but not identical jump starter. Chinese manufactured, it carries 3 lithium packs in series, charges through USB cable and it can provide either power for a USB consumer or a short burst of power through 2 clamps.
As it came from factory, it had a pack of Schottky diodes on the + wire, to protect from reverse polarity. Ordinary, board soldered Schottky diodes. This made it unusable, as there was no way this side of the laws of physics to fire 200 amps through them. Desoldered and removed the diodes and replaced them with a solid copper bar. It could give "a kick" to a weak battery and turn the starter motor. After 2 starts, its charge barely falls from 4 LEDs to 3. The jump starter is less than 1/2 lbs and it can be easily held in a coat pocket, like a big smartphone. Wires are 10 AWG, too thin to carry current for a sizable amount of time, but enough to fire a burst of current for 1-2 seconds, as needed for a jump start. |
