Just a couple of questions...
Ok folks, I've been thinking about a few things since I got my car out of the shop last week to have the a/c repaired to work for the coming summer. Now that I've been driving the car for about a week and have started getting used to the drag that the a/c puts on the engine I'm wondering what I can do to improve this while keeping the use of my a/c.
First off is that I don't use the a/c full time right now. I only use it on the highway portion of my drive to work in the morning as it's not warm enough at 7am to have it on. A couple of mornings have been more humid than the others so I ran it then to keep comfortable. However, when I do use the a/c I don't keep it on full time. I've gotten to the point that I turn the a/c off if I start up a long hill (a long hill is one that's more than a couple of hundred yards long) so that I'm not lagging behind the speed limit too far and my questions begin here. 1. Does turning the a/c on and off numerous times during a drive hurt the a/c or will it cause it to wear out sooner? 2. Should an a/c have a thermostat that will turn it off and on based on the temperature inside the cabin of the car? Right now, it seems as though my a/c is either on or off based on the short time that I've been using it. From here, my questions diverge into a few different areas because these are just a few of the stops that my train of thought has made in the last week. 3. Are underdrive pulleys really effective at improving the performance of an engine whether it is under load or not? And by 'under load' I mean having the a/c on at highway speed going uphill through 10 feet of snow both ways without shoes in the middle of summer with a horse trailer hitched up to the back of my car? ;) Ok so... maybe I exagerated a bit there. ;) 4. Do those adhesive 'vent visor' things work that are supposed to cover the leading edge of the front door window when it's open or are they just designed to keep rain and other funk from coming in through the window if I have it open a bit? 5. What kind of aerodynamic difference would I see between the following items, if any: a. An aero mod to the front of my car like basjoos uses on his car,To me, option 'a' would be the best but I'm not of a mind to do that to my car yet. I may be kicking myself in the rump for not following in basjoos's mods but I'm a sucker for the appearance of my car right now. That's it for now folks. I do apprecaite the forums here and the knowledge that is held within them. Thanks, Jeff. |
Thanks for the info JohnnyGrey, I do appreciate it.
