EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Just got my SG2, but it won't clear codes (https://ecomodder.com/forum/showthread.php/just-got-my-sg2-but-wont-clear-codes-16306.html)
AeroModder 03-02-2011 09:53 PM
I have one CEL code that's keeping the light on, and I believe I fixed the problem, but when I went to clear the code using the Scangauge, nothing happens, and the light stays on. The "force clear" method says "no response" every time I try it.
Any tricks on getting stubborn codes cleared out?
EDIT: Got it to clear the code, but it comes right back. Apparently, cleaning the EGR valve wasn't enough.
brucepick 03-02-2011 10:14 PM
I've had good luck calling LinearLogic (they make the SG) with difficult questions. They did their best and were forthcoming with whatever they knew on the topic. I think you'll find their number on their site.
Zerohour 03-03-2011 06:51 PM
What is the code? Not to be mean, but you do realize the CEL is on for a reason. Maybe resolving the issue would case the light to turn off the proper way. :-p Some items will trip the CEL immediately, so you vehicle (either the tempo or the aspire) could be tripping the light for a malfunction as the code is clearing.
