Just purchased a Scangauge II
what guidelines/methods you guys go by when testing your mpgs?
also how do i get max hp reading? i can see the HPR but not the max |
Before doing any testing, I highly suggest you to read the thread : How to properly test modifications if not already done.
i will try my test at 55mph late at night when no one is around .. |
I have a link (first one in my sig) w/ important sacngauge threads.
you want to find a drive that allows you to be warmed up and that is pretty level. Someplace you can always go to test a mod. I talk abpout that in the thread |
also i saw thread on your belly pan....good shyt ! |
Must admit, in the mild climate of Northern CA (sacramento) it was easy to work on it when ever I wanted! |
out here it can be challenging during the winter.. |
I think that I did belly pan 1.0 in december....in a car port!!! And not even thinking that the concret was cold!!!
