Just saying hi & introducing myself & my wonderful machine (boat tail CRX HF, 70 MPG)
8 Attachment(s)
hi everybody! i wanted to introduce my car and say thanks to all those whose postings i learned from. my car is a 1990 honda crx hf, 182000 miles. my mods are belly pan, 45 psi tires, passenger mirror delete, partial grill block, air deflector over the windshield wipers, rear fender skirts, deep cycle battery i charge every night since i have my alternator unplugged and tail cone. hey also, there is no mobile app for ecomodder is there?
Impressive mileage and boat tail :thumbup:
Is that folded coroplast ? How does it hold up to road use ? Do you plan to paint or wrap it ? (Coroplast will degrade in sunlight) |
Hi & welcome.
Sorry, no mobile app. :( I think the tail may be a bit long, but your fuel log seems to like it! (As well as your other mods.) Care to share what your typical driving is like? |
Welcome! Where did you come up with the info and inspiration do do your mods? Most folk show uo here then do their mods.
Do you mind me asking how your got your coroplast to make such smooth curves? I've never worked with the stuff but I have some being shipped to me for my boat tail.
For painting the tail I would recommend Krylon Fusion based on what I've read and what others have told me. |
1 Attachment(s)
If anyone was interested...
I assume the OP didn't follow the template from the top of the roof for visibility reasons but I would say it's still pretty effective because it runs back into the template later. |
Coroplast | Frequently Asked Questions Q: Is it possible to paint on Coroplast? A: Krylon FusionŽ Spray Paint for Plastics will provide a thin durable layer. Follow the manufactures directions for application of the spray paint. Brushes and rollers are not recommended for direct application of paints to Coroplast because the paint layer is too thick and can easily peel and delaminate. For art projects you may use brushed application of compatible paints on top of the "primer"/ base layer of the Krylon FusionŽ Spray Paint for Plastics. |
